-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   downconverted 24f in FCP 6 (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/98794-downconverted-24f-fcp-6-a.html)
Javier Marcheselli July 12th, 2007 11:45 AM
I’ve been having a rather difficult time trying to find the correct way to capture my 24f material into FCP. I shot HDV 24f and want to down convert using the camera (XH-A1) to DV 24f into FCP 6. I know how to capture straight HDV 24f using the preset in FCP, however my workflow requires me to down convert from the camera. When I try it now my footage doesn’t play smoothly or match frame to frame when compared to the same footage captured in HDV. Has anyone had experience doing this? Is there an “Easy Setup” option in FCP 6 that I should be using? I’m assuming it’s a frame rate setup problem. I need to know what preset I should be capturing with and what preset setting my Timeline should be at. I don’t see any other threads discussing the workflow for down converting HDV 24f with FCP 6. Any help would be greatly appreciated.
