Yes, I already ordered the SM5.
Hope it works out for you.
J-rod works great!
Well I took the advise of a couple of people on here and got 2 J-Rods. They work great! Only problem is the hot shoes aren't exactly "tight" and tend to loosen and the mike falls forward. So I had to remove them and use lock tight and now they are fine. Another advantage is with the extra shoe (I purchased the double J-Rod) now you can have a mic, audio, and light all on the camera.
I just used the same mic I had on my Sony PD 150 and it works fine but there is a piece of rubber around the mic right where the mount clamps down on the mic, maybe you could get an old inner tube from a tire or just buy a new one and cut it up and make a ruber boot for your mic to go between the mic and the holder that should work as a good shock mount and stop the sound transportation from the camera to the mic.
Well, the SM5 costs only 39 euro, so didn't take me long to decide. However it's going to take a few weeks before it arrives, so I might try a few of those tricks in the mean time.
Thanks. |
I'm using a AT897 and it's not picking up the zoom motor, but most definitely the sound of the tape that is recording. And also handling noises. I guess a shockmount wouldn't solve the microphone picking up the recording noises.
Depends on how the noise is coupled to the mic. If through sound waives in air, the shock mount will not help much, but if mechanically through the body and mount it will help more.
I'm pretty sure the noise that was recorded reaches the external mic via the camera body, not via air waves. Otherwise the built-in mic should also record it to some extent (which is not the case) and touching the camera is hardly audible with my own ears.
I noticed something peculiar. When playing a .M2T file in Windows Media Player 11 there's a high pitched sound. But when the same file is played in Vegas 7.0c there is only normal noise. The high tones are gone.
Thanks for the kind words about The J-Rod guys ! I am glad it is working so well for you.
I reached out to Steve and I think that is an isolated incident with the loose shoe. I will always offer to fix or replace any problems though ! |
