-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   A1 with Senn EW100 G2 RF interference (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/95850-a1-senn-ew100-g2-rf-interference.html)
Bill Busby June 5th, 2007 02:07 PM
I recently stopped mounting my receiver to the battery door of the A1 because of apparent RF interference. With squelch set to low on the EW100 (& mid on some occasions) & transmitter off, I'd get RF static & the RF indicator on the EW100 would light as well. Move it away from that location & it disappears. In fact the only place that emits this interference is near the battery door location. I've tried different freqs to no avail. There seems to be some shielding issues, either with the A1 or the EW100.
Does anyone using this combination velcro mount the receiver to the battery door, and if so do you get the same results as above? If not, could anyone test this by placing the EW100, turned on, squelch on low & up against the battery door?
When a transmitter (lav or plugin) is turned on though, this seems to go away... but I still suspect it was the cause of momentary dropouts in signal at times.
Any other areas around the A1 doesn't exhibit this & I've ended up using a Rycote hotshoe extender... but I always liked the balance better my previous way.
Just curious.
Bill
Deke Ryland June 5th, 2007 02:29 PM
Hey Bill... you might want to try what I do and just clip the receiver to your waist. I haven't had any problems doing that. I have a 4 ft XLR cable that I run from my waist to the camera that allows me to move around without much tether.. not to mention it takes the weight off the camera.
Bill Pryor June 5th, 2007 02:35 PM
I use the hotshoe clip that came with the system and mount it on the hot shoe. No problems at all there.
Bill Busby June 5th, 2007 05:06 PM
Bill, that's what I do now... except I use a hotshoe extender (4"). If you can find the time, try powering up both your EW100 G2 & A1 and place the EW100 (squelch on low) against the battery door. I just tried this again & noticed also it gets this RF interference at the right rear of the A1 as well, just behind the record trigger... where the jack pack on a G1 would be.
Deke, I thought about that a while back, but am already tethered as it is (power belt to run a Frezzi mini). >:-\
Bill
