How to put Presets on SD card without Reader, YES!
Since I usually am retrieving information from an SD card instead of putting info in, I do not own a card reader, i.e., I always use the device to read the card. So, to make it very simple. Go into your A1 custom preset screen and copy the first Default preset from camera to SD card. Once you do that, the camera will automatically create the "PRESET" folder. After this, simply turn your A1 dial to "Ext Control". Have it hooked to your firewire first of course, then download all the presets to your desktop. Open "My computer" and you will see "Canon Camera device" as another drive (something like that anyway). Click on this to open it. You will see a Folder....mine didn't show the name PRESET, but it was the PRESET folder, I just seen a picture of a folder. I then right click on the preset I downloaded from the desktop and COPY that file. I then right click on that folder PRESET. Choose "Paste into this folder"...and there you go..your preset is added. You CANNOT drag and drop for some reason. But if you copy and paste, it works perfectly. Did all presets within about 8 minutes. BTW, I do plan to get myself a card reader, but I didn't want to wait, it was late Friday night.
This is exactly how Console makes access to the card. Don't you have Console's drivers installed, BTW?
No, not at all. But I did download the English version of XH-TUNER. This may have installed a driver that allows this. But it takes about 2 seconds to download and it is free. You will not even use it to write to your card, but I suspect the driver is the reason the file can be viewed through the camera. I never thought of that. Good point. J
I had never really had any experience writing to an SD card so this was aggravating for me when I tried to load the presets to the card. I felt it should be able to load through the camera, I was disappointed to find that by design, it cannot unless you have third party software. So, I just kept bangin around until I figured this out. I am certain there are hundreds of people who would like to know how to do it..I hope this helps them in the future. J
Wow, I didn't know you could do that! I just learned something new, thanks for this tip John.
any luck with this workflow on a mac?
Now....does anyone know if this will work on the XLh1? Peace! |
No reason why it shouldn't work with the XL H1 -- now who will be the first to confirm it?
I started this site in order to learn more about digital video. If I'm not learning, I'm not living. |
I am glad I finally contributed something useful! Now I have to go back and post more questions about Vegas and codecs... geez
| All times are GMT -6. The time now is 01:20 AM. |
