-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   FCP settings to capture 60i (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/93776-fcp-settings-capture-60i.html)
Neil Anderson May 10th, 2007 11:23 PM
Ok guys, I shot in 60i and need to capture it in Final Cut Pro. What settings should I have FCP on? Please help!
Jim Miller May 11th, 2007 07:44 AM
Use easy set up and select HDV-1080i60.
Establish a new sequence in the timelime and make sure it is set to HDV-1080i60 as well and you're ready to go.
Matthew St. Carrell July 17th, 2007 12:07 AM
same problem
I did try the HDV Easy Setup...
I recently purchased an A1 & shot some footage on it yesterday. The camera is set to 1080i/60i with the down convert turned off (per manual instructions).
When I opened the project in FCP, I did the Easy Setup for HDV.
The capture was glitchy. I would capture "Clip" and half the time I would get a timecode error message. I would just try it again and usually it would begin capture.
No matter what I did, I only got video with no audio.
I tried all the settings on the camera & in FCP that I could to no avail.
I tried to customize my capture preferences too, but the HDV preferences are locked and the Edit & Duplicate buttons are greyed out.
And not only no audio, but the video shows up unrendered on the timeline.
Any ideas?
