Well the CA looks not as bad from the standpoint of the full frame image.
You can download some wallpapers to fix the other problem in post ;-) Thanks for posting those. The reason I'm curious about the full frame grabs is not related to the CA, but the observation I had while viewing on the small LCD screen that when viewing barcodes (vertically and horizontally), that the HDF set to "low" increased the resolution and contrast in the horizontal direction, and that DHV set to +9 increased the apparent contrast and resolution in the vertical direction. But it was not scientific at all, I didn't have a proper monitor connected, so moire and aliasing could contribute to a false conclusion being drawn from the LCD screen alone. |
Thanks, Alex, for your tests! |
Although it's been proved that the optical component of the fringing does not completely go away, the observation that Wolfgang's preset makes the problem worse is some justification to say that presets do have an influence. We may disagree on how significant, but the preset I'm using, basically Steven Dempsey's VividRGB but with normal gamma, seems very good about minimizing CA for me with still vibrant color. I really like this preset.
But I should try Wolfgang's also...dumb question but where can I find them? |
Tom, here is the the link:
http://www.fxsupport.de/20.html Just go to line that says: "Alle vier Presets zum Downloaden: PRESET.zip [ZIP 1KB]" I used the (slightly modified) -3db preset, the first of Wolfgang's four presets you find in the folder. I'd be very interested in how you like them. |
is this with a wide angle or the normal lense on the A1? (or G1?) How bad does it fringe in normal filming?
The fringe is not visible in normal filming. You only see it on areas of particularly high contrast when zoomed out wider than half way.
I downloaded the promotional video for the XH-A1/G1 from Canon (I think they took it out of circulation) and many of the scenes had fairly significant CA. I have to say that it does not look like the CA that I am used to with still cameras, it was not a sharp fringe, but a gradual color shift around edges that looks more like a prism effect. It may be a design issue with the prism that is used to split the colors up for the three sensors. It is the most significant issue that is keeping me from buying the XH-A1. If you just look at the central part of the image, it looks very good.
