-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   what kind of cleaning tape do you use with XH A1? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/90840-what-kind-cleaning-tape-do-you-use-xh-a1.html)
Leila Alkadi April 5th, 2007 11:13 PM
I've finally reached 100 hours on mine. (50 tapes
used so far... figuring 1 hour recording + 1 hour
playback, times 50 = 100 hours) I never re-use
the tapes...
Any advice appreciated!
Don Palomaki April 6th, 2007 04:52 AM
And brand name dry MiniDV cleaning tape should be OK. See page 147 of the Instruction Manual. I've been using Sony brand with other Canons but have a new Panasonic brand on order.
James Hooey April 6th, 2007 10:59 PM
I use Sony HDV tapes for recording...but Maxell cleaning tapes. No issues. I might suggest cleaning a little more often than 100 hours though. My typical regime is about once every 10 hours or so.
Rick Sharf April 7th, 2007 02:14 PM
do you need a new cleaning tape for every use?
Mike Teutsch April 7th, 2007 02:29 PM
The cleaning tape is only run for approximately 10 seconds per use. The tape itself is probably 5-10 minutes in length. You use it for the 10 seconds and remove it. When you run out of tape you throw it away.
Never rewind the cleaning tape or you will be putting what you cleaned off before back on!
I don't believe the brand makes any difference.
Mike
