-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   "card to camera" not highlighted? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/88867-card-camera-not-highlighted.html)
Dom Stevenson March 13th, 2007 05:16 PM
On Sunday i bought a USB SD card reader and downloaded the presets off this site. When i go in to the customize section of the menu theres a long rectangular panel on the left that i'm supposed to scroll down to the Card to Camera option, but the third option (the one i'm after) does not light up, and is thus inaccessible. I have tried taking out the card and putting it back again a couple of times but still no recognition by the camera. Any ideas?
Dearl Golden March 13th, 2007 08:15 PM
The presets should be downloaded and saved to a folder on the card (that you create) named PRESET....singular, all CAPS.
One other consideration....did you format (prepare) the card in camera or using your OS and new card reader?
Chris Hurd March 13th, 2007 08:41 PM
Also there's no real need to move the presets from the card to the camera. You can access them from the card just as easily as if they were in the camera.
Dom Stevenson March 14th, 2007 05:27 AM
Dearl and Chris,
Yes i did call it PRESET.
No i didn't format the card in OS or camera. Is that likely to be the problem?
I'm on the mac if that's relevant in any way?
I got so bored trying to do it last night that i finally dialled in the panalook preset manually and renamed it as preset no 4 in my camera, and naturlo as no 5. Still it would be nice to have the option of having all 18 available on the card. No, i don't need to have them on the camera.
Thanks for your help.
Chris Hurd March 14th, 2007 06:51 AM
Format the card in the camera, then move one of the three included presets over to the card. That should correctly establish the PRESET folder and allow the camera to see those files once you've downloaded them again.
Dom Stevenson March 14th, 2007 03:39 PM
Thanks Chris.
You wrote `"Format the card in the camera, then move one of the three included presets over to the card." and sure enough i now have access to the card. However, when i follow the instructions on page 77 (as opposed to 81 - A pal version difference?) "loading a custom preset from the memory card" i click on the blue import option but there's nothing to select. I take the card out (yet again) and insert it into the card reader on my mac and it seems all 18 presets are present. I put it back in the camera and NADA. There is a green card icon on the LCD with the number 13 to the right of it in white numbers. sorry to go on but it seems that i'm not quite there yet.
Any thoughts?
Chris Hurd March 14th, 2007 03:55 PM
Hi Dom, that just tells you that you have the ability to take 13 still photos before the card fills up. If this is in the upper right hand corner of the screen, then it's also telling you that you're in "card camera" (still photo) mode. Put it back in video mode using the slide switch on the back right side of the camera.
Now try this test. Press the CP on / off button on the bottom left side of the camera in order to activate the presets. Now use the CP select button next to it, in order to advance through all of the preset files. You should be able to cycle through all nine in the camera's memory and then it will automatically jump to those on the card. There will be a little card icon next to the CP number to tell you that you're cycling through the ones on the card. Does that work?
Dom Stevenson March 14th, 2007 04:43 PM
OK Chris :
I press on/off custom button,a CP icon flashes with a 1 next to it.
I press the select button next door and go through to 9 which is followed by a smaller cp icon with a 1 beside it. I push again and i get a flashing (back to large size) CP off icon, which is followed by the CP 1 again and so forth....
Thanks for helping out Chris
Hang on. I TURNED IT OFF INSTEAD OF ON...DOH! however once turned on i'm just going round in circles from one to nine. What concerns me is that when i press the import button nothing happens suggesting there's nothing there, or more likely that the cameras not reading them.
Just put the card in to my mac (again) and opened the folder titled PRESET. there is a greyed out file called PRESET01.CPF I think this is one that i copied from my camera as you suggested Chris. Then there are the 18 files i downloaded but they are white with HTTP @ written on them. The names of the files are PRESET01.CPF.webloc etc and are not the same as the one i captured off the cam. There final file is the one with all the presets on it and is also called .webloc and had an @http like the other 18. Was i supposed to do something to these files before i put them in the PRESET folder?
Chris Hurd March 14th, 2007 05:24 PM
Originally Posted by Dom Stevenson (Post 641763)
...they are white with HTTP @ written on them. The names of the files are PRESET01.CPF.webloc etc and are not the same as the one i captured off the cam.
Well that is definitely the problem then. The file names must be PRESET01.CPF, PRESET02.CPF etc. and nothing else... it's the "webloc" and "http" that's messing you up. The camcorder can't recognize that. The file extension must be .CPF and nothing else.
Dom Stevenson March 14th, 2007 05:49 PM
Chris...You're a star. And I'm an idiot.
You've made my day - or night i should say. I have to get up in a few hours, but i can't wait till the weekend when i can get out and start playing with these things.
Many thanks for all your help this evening.
