-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   A1 Preset Adjustments... detailed explanations? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/88210-a1-preset-adjustments-detailed-explanations.html)
Jerome Cloninger March 5th, 2007 05:11 PM
Just wondering if anyone can shed the light on EXACTLY what each setting does... though some are obvious.... Thoughjt I'd ask because I haven't seen too much info on these settings. Some I've played with while previewing on my monitor but can't reall tell a difference, but still want to know what it does.
Knee: I know adjusts the rolloff of the whites and brights. Lower means that it keeps details at brighter levels without going white.
BLACK: Obvious
MASTER PEDESTAL:
SETUP LEVEL:
H DTL FREQ:
DTL HV BAL:
CORING:
NR1: Appears to smooth out grain, but leaves ghosting.
NR2: How does this work?
COLOR PHASE:
Even Solberg March 5th, 2007 05:35 PM
Hi Jerome,
Have a peek here: http://www.usa.canon.com/app/html/XL..._control.shtml
This is for the XL H1, but the same applies to the XH A1.
Jerome Cloninger March 5th, 2007 05:46 PM
Originally Posted by Even Solberg (Post 636494)
Hi Jerome,
Thanks, that helps... but I'd still like to know more about these two:
H DTL FREQ:
DTL HV BAL:
Josh Laronge March 5th, 2007 06:10 PM
It's all explaned here for the XH A1. Click on Manual Adjustment.
http://www.usa.canon.com/app/html/HDV/XHA1/index.shtml
Jerome Cloninger March 5th, 2007 06:13 PM
But for those 2 it doesn't really describe it.... and when I hook the cam up to my HD monitor and sdjust these two, I CAN'T tell a difference.
"H Detail adjustment: This adjusts the center frequency of the H detail. The center frequency in the horizontal direction can be set to "HIGH" (high range), MIDDLE (middle range), and LOW (low range).
H/V balance adjustment: For adjusting the horizontal/vertical percentage of detail correction. This is adjusted to suit the user's personal preference. Adjustment is possible in the -9 to +9 range.
Josh Laronge March 5th, 2007 06:22 PM
I don't know the explanation of it. I do know mine are set to whatever the default is and I love the images from the cam. It may be a setting that you will only notice a difference under optimal test conditions.
