-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Tripod Mounted A1 - Image Stabilizer On or Off? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/86949-tripod-mounted-a1-image-stabilizer-off.html)
Neil McLean February 19th, 2007 05:44 PM
Quote from Page 51 of the manual... "We recommend you turn off the image stabilizer when mounting the camera on a tripod."
I'll be filming a cheerleading event this weekend and just wanted to confirm it's best to switch off the image stabilizer when filming on sticks.
I'm in PAL land, so 1080 x 50i will be sufficient for my needs. I am however, somewhat undecided about which shutter speed to fix. I've only selected 1/50 in the past, though I'm tempted to increase this a tad.
I'd be keen to hear from folk who have had more experiences with their A1.
Many thanks
Neil
P.S. Being used to PD150s and PD170s, I was tempted with the HVR-Z1, though I was eventually put off by the x12 zoom. This then lend me to believe the HVR-V1 c/w x20 zoom was the camera for me, though I was eventually put off by the smaller 62mm lens and the somewhat smaller FOV.
P.P.S. I'm sure I'll have no regrets about my choice of camera 8-)
Bill Pryor February 19th, 2007 06:16 PM
Yes, definitely turn it off when you're on the tripod. If you don't, you may see trailing images when you make a fast pan. Both the Z1 and XH A1 are good for what you're doing, the XH A1 being a little better because of its longer lens.
Dom Stevenson February 20th, 2007 01:06 PM
Cheerleaders in the UK Neil?
Last time i saw anything like that on these shores was the Hemsby rockabilly festival near Yarmouth.
Neil McLean February 20th, 2007 04:03 PM
Hi Dom,
Yeah - cheerleading seems to have taken off really well in the U.K. I can only imagine it stems back to the days when there were quite a few American football teams competing in the British leagues.
After the teams folded, from what I can gather, the team's cheerleaders then went on to cheer for the local football teams and rugby teams etc.
I've got a rather long drive down to South Wales for the next event this coming weekend.
Neil
Bill Pryor February 20th, 2007 04:05 PM
If American football is called football in the UK, does that mean they don't call soccer football?
Byron Huskey February 20th, 2007 04:33 PM
I'm asusming he meant American (soccer) teams, although they do call our football "American Football", so that wording was a little confusing. I'm certain soccer is still football, and will be for all time everywhere but here, heh.
Neil McLean February 20th, 2007 04:56 PM
I thought about using the word soccer, but seeing Dom is located in the U.K. I felt this would have perhaps confused the issue for him.
Yip meant American football - pads et al, NFL etc etc.
HAIL TO THE REDSKINS!
Frederic Gittler February 21st, 2007 07:22 AM
Yes, the manual recommends to turn off the image stabilizer when mounting the camera on a tripod...
My experience is actually slightly different. Fast camera movements should work best with the stabilizer off... if the movement is (reasonably) fluid to begin with. I have found out that my setup is not rigid enough when tracking an object near full telephoto (650mm equivalent for a 35mm camera); I get better results with the stabilizer in these conditions.
I would say there is no absolute answer: it all depends on the quality of your tripod, the zoom range (wide-angle vs. telephoto), and the type of camera movements.
Simon Dean February 21st, 2007 07:57 AM
I forgot to turn it off when using a tripod the other day ('cause you have to go into the menu to do it) and it was no problem - it was a fairly smooth tracking shot though, not too quick. So as above, I think it varies...I had a bad experience with a PD170 when I left it on and had that strange jerky movement so in general I would turn it off.
I guess I'm saying that if you forget because you're in a rush (I was - and there's no button for it!) then it doesn't always mean your footage will be bad.
Bill Pryor February 21st, 2007 09:24 AM
Not always, but you definitely want to avoid any moves other than very slow ones.
Neil McLean February 21st, 2007 10:22 AM
Okay guys - you've convinced me! - thanks!
I'll be on a tripod all day, so I'm make sure I switch it off before I start the shoot.
Thanks once again
Neil
Dave Mody February 22nd, 2007 09:37 PM
I dunno about this... I think it depends
I haven't had the experience with the A1, but all the canon IS lenses I've used have benefitted from using the IS, but that's because I'm usually standing on a beach in 20 knots of wind and there's no tripod I've ever seen that doesn't shake a bit in those conditions. ... That's just my thought.
Cheers Dave
PS what's football? :)
