-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   A1 White Balance in Plain English (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/84631-a1-white-balance-plain-english.html)
Geoffrey Baker January 23rd, 2007 02:25 PM
I’ve read the white balance section in the manual and been shooting some tests.
Can someone confirm my understanding of the options to white balance, and answer a few questions….in plain English. My hope is that this discussion will help the next person to ask. I could not find the answers in searching the forum.
To whit:
Option 1, Auto – Slide the AWB switch on the side of the camera to on and trust the white balance to the “mind of Canon.”
Option 2, Pre - Slide the AWB on the side of the camera to off and set the camera to manual mode. Set the white balance toggle switch on the side of the camera to pre. Under the lid of the LCD, slide the selector switch to Outdoor, or Indoor or Kelvin. If Kelvin is selected, press the white balance button, display flashes, turn the Kelvin dial on the side of the camera to your temp, press the white balance button again. Your Kelvin temp is now set.
The manual goes on to detail how to fine tune the white balance while Outdoor or Indoor are selected on the top slider and adjusting the Kelvin dial. What are the values -9 to +9 supposed to represent?
Option 3, Custom - Slide the AWB on the side of the camera to off and set the camera to manual mode. Set the white balance toggle switch on the side of the camera to A or B. Fill the frame with white object. Press white balance button. Wait till white balance display stops flashing and you are balanced. The balance is stored in A or B.
Now a question. I’d like to be able to dial in two Kelvin temps and store them via the A or B preset button on the side of the camera. It is not at all clear how to do so. In option 3 above you can store a white balance, but only using a white card and not dialing in the temp. Is it possible?
Whew. Steep learning curve here, but loving it.
Thanks in advance.
Piotr Wozniacki January 23rd, 2007 02:31 PM
Hi Geoffrey, and welcome!
I'm afraid dialing direct Kelvin valuses into A or B presets is not possible; please see here:
http://www.dvinfo.net/conf/showthrea...t=78730&page=8
