FWIW worth, I spent the evening with a digital SLR mounted above the XH A1, comparing different focal lengths. Everything between 35mm and 135mm matched very closely with the EXIF data - including the FOV. So I'm inclined to use the numbers from the EXIF data to calculate the 35mm equivalent.
Well I'm still at a loss as to why there's so much disparity between the EXIF data and the F.O.V. test... but...
*If* we accept the EXIF data as valid, then here's a *rough* 35mm equivalency scale for commonly used focal lengths (except I know I'm missing a few of the more common 35mm focal lengths -- what are they?): Code:
Z00 32.5mm |
I've used Chris's method and a multiplication factor of 7.2222222 to determine some of the more common focal lengths as they relate to Z#s. Hope this is helpful to you all...
To get as uniform a reading as possible, I set the zoom speed to 1 and gently tapped the zoom button until the Z# changed thus taking the reading from the very start of the zoom value as opposed to midway through (that is, you can actually zoom through Z5 a little bit before it changes to Z6 etc.) all the values are usually accurate within a couple of tenths of a milimeter though at the upper end of the range (180mm and 300mm) they are within 2mm. 32.5mm=z0 35mm=z5 40mm=z12 50mm=z24 65mm=z37 75mm=z43 85mm=z48 100mm=z54 135mm=z64 150mm=z67 180mm=z72 300mm=z85 |
whoops! just noticed that my post is pretty much a repeat of your last one chris. Didn't mean to steal your thunder lol but I guess I over looked that last post. Anyways, seems like our numbers are pretty similar.
It's all good Cal. Reassures me that we're coming up with the same numbers.
Chris, Cal, this is brilliant, thanks for working this out. I think in 35mm focal lengths and tend to be quite organised (read: pedantic) about what lens length is used for what shots so it's always irritated me not really knowing what focal length I was shooting at, even roughly. I'm printing a list of 35mm equivalents and sticking it to the back of my camcorder.
Nic |
