-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   "Moire Patterning" Canon XH A1 (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/80863-moire-patterning-canon-xh-a1.html)
John Huling December 3rd, 2006 07:45 AM
I shot some footage last night of some performers, most low light. Some footage (if it's still called that... maybe "mm's" now) was shot in quite bright light. What I noticed this morning on play back is on a 26 inch Sony HDV tv from the componet outs of the camera, is that there is some "moire patterning" happening around the details. For example, there is a shot of a leafless tree against the sky and a couch in a nother shot with a line pattern in it's print. The tree and couch in both shots are sort of shimmering...not good! Any ideas of what is going on?
Pete Bauer December 3rd, 2006 08:25 AM
Hard to know without seeing the footage, but it could either just be too much fine detail, vertical detail set too high, or sharpening set too high, or could even be display-specific...? Can you either link to a short m2t or failing that post a few successive frame grabs at full-rez?
Marty Hudzik December 3rd, 2006 11:01 AM
I sometimes see a minor moire patterning on certain clips when viewing on a 26" HD CRT. I believe it is a 1280x720 screen.
The same footage on my 45" Aquos LCD panel that is 1920x1080 native looks flawless. I'm not saying for sure that is your dispaly but it is a possibility as Pete mentioned already.
John Huling December 3rd, 2006 11:17 AM
I don't have any clips I can post as of yet. Perhaps this evening. Should'nt the image look "right" on all screens as long as they are HD. Even when I made a DVD converted to SD. It does the same thing. Oversharpening is what it looks like though. Same thing I have seen with my Canon Still. Maybe A1 default settings are over sharpened...I will check the settings.
Bogdan Tyburczy December 3rd, 2006 11:44 AM
I agree with Marty. It seems like it's caused by the monitor. Import the scene to your computer and check if the problem is still visible in 100% scale.
On native 1920x1080 screen it should be fine.
John Huling December 3rd, 2006 11:50 AM
Is this why Sony new HDTV's with 1920 X 1080 resolution? I am just using my Sony Vaio laptop to edit a few things right now with Vegas 7
Bogdan Tyburczy December 3rd, 2006 12:03 PM
When scaling down, some monitors and TV's may exhibit problems like that. After few years of profit making with sub-standard HD TVs and monitors, technology and marketing has opened the door to affordable native 1080p. Good for new customers, but people who spent a lot of money on 1080i or someting in between 1080 and 720p may be a little bit angry. The show goes on.
John Huling December 3rd, 2006 12:07 PM
Thanks Pete
I will take it back to BestBuy and get the XBR 1080 X 1920 Version
John Huling December 3rd, 2006 04:15 PM
Sharpening on TV not A1 Camera was culprit
Sharpening on the TV was the cause of the moire. Do most people turn off the sharpening on the Canon A1? It seems to over sharpen a bit...
Chris Hurd December 3rd, 2006 05:08 PM
Sharpening isn't something you can "turn off" on the XH camcorders. You can turn it up or down though, using the Custom Preset function. Sharpness control ranges from -9 steps (softer) to +9 steps (sharper) than the default out-of-the-box look.
Jay Fisk December 3rd, 2006 06:00 PM
Thanks Pete
I found the XBR's glass surround distracting but the enhanced SD upconversion might be handy.
The basic KDL46V251L1's (same as KDL46V2500 at BB) lasted at Costco for a few hours at $3249. Costco bumps Sony's standard one year parts, 90 day labor to 18 month inclusive.
John Huling December 3rd, 2006 06:45 PM
Thanks Chris
I meant turn down. I found the control on the camera. The Sony HDTV goes from 0-30 or something like that. It defaulted at 18. I turned it down to 12 and the patterning moire went away. I just wondered since I don't seem to see the moire on Standard broadcast if setting the A1's sharpening down might be more consistant with broadcast standard. Canon's DIIs and 5D still cameras have sharpening settings that are fully adjustable from 0 to 5 or more in some cases. Generally one wants to wait to do sharpening to the very last. Does that apply to video?
