Canon XH A1/G1 vs. JVC GY-HD110U
i am on the fence on which of the two to purchase. both seem relatively similar, but maybe i am missing something. right now i am leaning towards the canon XH series. any suggestions or thoughts???
realizing we can't know too much about the XH series, what are some thoughts on canon vs. jvc vs. panasonic?? any info or thoughts would be greatly appreciated... |
at this point I'm going with the Canon A1. Never care much for the JVC. Maybe Panasonic or Sony will do something soon.
Well, the XHA1/G1 is essentially the same as the XLH1 ... same DIGIC II processing, same censor...the 20x zoom lenses seem identical, except the XH-series lens is fixed. I guess if you like the images the XLH1 produces, and you like the form factor of the FX1/Z1, go with Canon. JVC...it's a nice camera, but there's nothing earthshattering about it.
Choose your format, then choose your camera. The prices might be similar but they are completely different systems... 720p vs. 1080i, interchangeable broadcast video lenses vs. fixed built-in zoom lens, etc.
Just a small clarification: the XH cameras and the XL H1 lens are both 20x, but not the same lenses. Different number of elements and groupings than the XL lens. The XH cameras go a bit wider, and not quite as long.
http://www.dvinfo.net/canonxh/xhfaq.php http://www.dvinfo.net/conf/showpost....0&postcount=78 |
I have been most impressed with Canon's XL H1 low light performance.
I based this on a comparison with the XL1s. The XL H1, in my opinion, is definitely better. This was a big surprise to me as I expected it to be worse. |
I like the JVC a lot, but the issue of choosing formats isn't quite so simple from my viewpoint. I've done a lot of testing and conversions comparing footage from both cameras, and IMHO Canon HDV is more multi-format friendly if you know what you're doing. HDV 24F looks pretty dang good as 1080 24p, and it's simply phenomenally sharp and crisp in the 720 frame, with even more color sampling comparatively due to the 4:2:0 of a 1080 frame converted to 720.
1080i also converts VERY well to 720 60p by a number of post methods, and I think that is due to the extra horizontal resolution of the format. To be fair, JVC 720 24p faired pretty well bumped up to the 1080 frame, but it didn't look nearly as sharp as Canon 24F can look. These cameras are all mish-mash of compromises so look at the footage posted and decide what camera's look you like best and then consider the tradeoffs (fixed lens vs. interchangeable, etc.) and make your move. |
thanks for the note. that does help quite a bit.
I've shot with both a JVC HD100 and a Canon XLH1, and with Sony Z1U, which will be similar in form factor to the new Canons coming out.
The biggest difference between them is ergonomics -- the image from all can be tweaked every which way, depending on what you want. The JVC has the best ergonomics -- you can learn to operate it by touch in only a short time. The controls make sense. The lens is all manual. If you are more comfortable with an all-manual camera you will be very happy. The shoulder-mount balance is not great but is way better than the Canon. The little A1 camera, however, has the top-mount lcd and handle which makes low shots really easy. It's easy to transport. It's lighter. It's less intimidating. It travels more easily. It will be easier to use in tight spots or from weird angles. It is, however, harder to hand-hold. So it depends on your needs. For travel and run-and-gun, the new smaller Canons would probably be better. For shoulder-mount hand held doc work, get the JVC. If you're shooting a narrative locked on a 'pod, the JVC probably wins, unless you need the 20x zoom on the Canon and don't have the scratch for a different lens on the JVC. The biggest factor, however, is editing: if you really want 24p, you probably need to figure out your editing workflow before picking the camera. Chuck |
I still love the JVC. The problem I have with the new Canon's is that you lose a lot of resolution when in 24f mode.
What is really amazing with this latest generation, is that discussions between the cameras are indeterminate. There is no deciding feature set that makes one the 'must have camera'. The Z1 may even fit in that, although it is maybe a half-generation behind with lower resolution and a 24f mode that is not up to the Canons (based on reviews).
My caveat would be audience dependent. If the target audience is Internet, using current/previous generation HD TVs (1280x720 or 1328x768). or current/next generation HD TVs (1080p). All of the cameras work. All of the cameras are subject to tuning. All of the cameras have compromises. Another issue would be total cost and features. For example, if you are a PC editor, would $1300 be better spent on ProspectHD? Filters? A 35mm DOF adapter? Or better lighting and grip equipment? |
However, as stated, all these cameras are good. The A1 is very attractive in a price/feature comparison. |
Pete Bauer would know as well as he was also in attendance at the Texas Shootout.
Choose your format first, be it either 720p or 1080i or something else; then choose your camera. More importantly, realize that your equipment does not affect "image quality" in any way. You can create award-winning video a cel phone camera. Pixel count does not make or break the quality of your image. What you point the camera at, and how you point it, is what governs image quality. |
I would suggest that a drop from 1440x1080 to 800x540 in Frame Mode is a lot. But as Chris suggests it is really about what you need. Like the Panasonic 200 the 1080 is interlaced and if you are going to shoot in a progressive mode or frame mode you lose resolution taking it below where the JVC's progressive resolution is. If resolution in frame is not your primary concern the new Canon's seem a steal to me at $4000. Especially if you are looking to use something like a Redrock 35mm adapter. I have been using the JVC with a Redrock M2 and it is really, really long. If you plan to use a stock lens I am quite sure that the Canon is much better glass. On the other hand I prefer a true manual focus lens like the one of the JVC.
Original Poster: what will be your primary use for the camera and what type of cameras and lenses are you use to working with? I think the answers to these questions will help point you in the right direction. I have heard people say that the learning curve on the JVC is high, I didn't find that to be the case but that has to do with the cameras I have worked with in the past. Personally I would love to get my hands on one of the new Canon's.
i am quite new to this site, and really to the more sophisticated world of DV. the primary use for this camera will b for lower budget short films and documentaries. i edit with FCP. as a still photographer, i always used canon and enjoyed their performance and interface. my previous shorts were shot in 8mm, so HD will be quite a welcome jump.
my decision on the camera will depend on it's ability to shoot in low light, versitility (in the A1's case, with the fixed lens), and the ability to obtain a "film-like" feel/appearance - statistics aside, if lower res would equal a more realistic "35mm" look, than that is something i would consider a plus. i can't tell you how impressed i have been by the wealth of knowledge on this site and the amount i have learned in this thread alone. thanks for all the input!! |
Joseph...the first time i shot something with a 24p camera i was really blown away by how much it really did look like film. The contrast ratio isn't the same but I was impressed. The one thing I found missing was the depth of field look. There are a few good articles on DVinfo about achieving a shallow depth of field by cheating your iris open and us ND filters. Recently I have been using a 35mm adapter, there are several options available now. They allow use to use prime still lenses and give that depth of field look that you can aler by adjusting your f stop. Take a look out in the main forum at the P+S Tech page and alternative image pages. And if you like the Canon's and are familiar with them then that is half the battle as far as I'm concerned. Best of Luck with which ever route you choose!
that sounds good.
would a 35mm converter work on the new XH series, seeing how the lenses appear to be fixed? if not, would the difference be great enough to then look more seriously at the JVC? |
I believe that you need an interchangable lens to use most 35mm adapters.
If there is one that used the fixed lens, then I expect someone will make a post to that effect. What are your plans for the camera? Are you going to make films? Edit: Aaron Frick, below, posted that adapters do indeed exist for fixed lens cameras. I stand corrected. |
i will be doing mostly short film with a few documentaries. for the most part, the films are for festival circuits and resume' pieces.
have you compared the difference between using the converter vs. the effect in post? |
By "doing the effect in post", I assume you mean creating a shallow depth of field, by unsharpening the background in an otherwise "in focus" video.
If this is the case, then I feel that this would only be feasible if you had very little movement in the scenes and you had a lot of time to do the effect in post. Please let me know if you meant something else. |
I am using a Redrock M2 and it works on fixed lens camera. Even with the JVC you have to fit it over the stock lens as they do not have a relay lens out yet. The P+S Tech also works with fixed lens camera, but they do have relay lenses available for cameras that have interchangable lens systems. If you were to get a 35mm adapter then the JVC lens would actually be a disadvantage in my opinion. It makes the camera very long. The new Canon's look like they would be great for using 35mm adapter.
Aaron, I think you're mixing and matching the very different terms "effective pixel count" and "lines of resolution." I'll leave it at this: it is my opinion that NOT using Canon 24F mode simply because its resolution is a little less than the same camera's 60i mode is a mistaken idea.
Picture detail, which I'll define as the product of horizontal and vertical resolution in line pairs, is just one of many variables in the largely subjective pursuit of finding "the best picture." The picture detail of 24F is not inferior to the progressive images of other cameras in its price class. The only camera in that range that gives it a run for its money in motionless luma charts of 24fps images was the HD100, at 700x700 (which I thought was a bit generous; I'd have called it 700x640). Adam called the Canon F-Mode at 800x540, but I don't have those images to look at. My own test, put F-Mode at 800x600 +/-20 lines in each directions. And in actual shooting of video with motion the Canon codec does an admirable job, so I think that this constant picking at F-mode for "lost resolution" is as pointless as people complaining about the out-of-the box color in any of these new cameras that are totally tweakable from luma to party colors. So as has been said many times already, people should choose a camera within their price range based on ergonomics, workflow, features. They all look great in skilled hands. |
Peter: Fair enough and well said. Why is it that we are constantly hearing these report comparing these numbers? I fully understand buying a camera that fits your needs. I would not invest in the Panasonic 200, not becuase of whatever the pixel count is in 24p but because P2 just wouldn't work for what i do. It seems that all I read in magazines and online is about pixels and resolution. AARRGH!
As what was said earlier, it depends on what you shoot. I do a lot of Doc work & couldn't live without the auto-focus & image stabilizer. The over-crank under crank of the new JVC is tempting though. I'm also used to the canons (XL1s), so I'm partial, plus I have batteries etc. and the thought of having everything that I need from the HD1 for $4000 is a no brainer for me.
Chris |
there is one more thing i am a bit curious, that i don't think has been touched on yet.
i have enjoyed working with canon over the past few years because of the durability i have found in ther products. of the companies discussed, any feelings on durability, customer service, product resources... |
Just what I can say about the canon (XL1s)
I've had it for 4+ years without any problems, running it in all kinds of weather. Chris |
jvc durability
Been using the JVC now for about 2 months, its solid, and Andrew Young is it who shot with one for the Madagascar doc even dropped it in the drink, dried it out and continued on.
But in that regard, the only concern I have is the evf, its not the most solid looking item, and would be something I hope is looked at for the HD200 or HD250. |
I just put our XLH1 through a hellacious shoot, daylight, night, warm weather, humid weather, dust, smoke and artificial rain.
And then XLH1 said, "is that all you got bitch!" |
In my first week of ownership I subjected my XL-H1 to hours an hours of extremely cold weather in Park City, UT during the Sundance FF.
I had the same sassy response from my cam too, Robert. :-) |
I love the ergonomics of the JVC (especially love the focus assist) but it really needs a better lens IMHO, even if it has that "pro manual feel". The other thing to consider is that the HD100 is 24 and 30p HDV only. (I don't consider "motion smoothing" to be a reasonable facsimile of standard 60i/p video) There's also something to be said for 1080i, in that it produces a super crisp hyper-real look, which has its place for television/documentary production. |
I'm a happy owner of the Panasonic HVX, and am quite happy with it. The main advantage with it is the dvcprohd codec. Also, the variable frame rates and the possibility of shooting 720p60 at 4:2:2 is something no other camera in the price range offers. Resolution is not everything. I've seen my footage in a 50" plasma screen and I was stunned with the quality.
But you're right, every camera has its advantages and disadvantages. The HVX was the camera for me, and I'm quite happy with it. The A1 seems like a good proposition. I wouldn't use HDV for editing, tough- I would suggest getting a AJA or Decklink card for capturing trough the component outs and working with the DVCPROHD codec. |
The 1440x1080 you're refering to is not the resolution of the camera per se, but what is laid to tape in the 1080i flavour of HDV. It doesn't matter whether you shoot standard interlaced or frame mode, it will be laid to tape at 1440x1080, and then stretched by your NLE/monitor to 16:9 frame for post production/viewing (exactly the same as the Sonys, even though the image is softer). In the case of your JVC, the data is laid to tape at 1280x720, but again, this is not the resolution of the camera (which is a function of the camera head, lens, DSP and so on), but merely the HDV 720p codec. The 800x540 you mention from Adam's tests is the resolution he measured coming from the camera itself (I believe this was HDV independent because he used the SDI outputs). These are TV lines of res, or lines per picture height, so you can effectively times the vertical number by 1.77 to fill the 16:9 frame, meaning the XLH1 can resolve something like 1420x540 total pixels in frame mode, as opposed to 1420x800 in interlaced mode (both laid to tape, as mentioned, within the 1440x1080 HDV scheme). With the JVC, it will be something like 1240x700, close to the limits of the codec. And as Pete said, those numbers may be a little generous for the JVC, and a little lean on the Canon side. If anything the Canon, even in frame mode, has the edge in sharpness. In any case, resolution is not a real point of difference between the Canon cams and the HD100. If you want to see 24F in action, take a look here:http://www.dvinfo.net/conf/forumdisplay.php?f=126 Steven Dempsey - among others - has put up some really beautiful XL-H1 24f shots recently. |
