My number one fear about the XH G1/A1
I own a DVX100 and an XL2. I really like both cameras and use them both. Both have strenghs and weaknesses. But the number one thing I dont like about the XL2 is the frame judder associated with shooting a 24p pan shot.
If you have the camera in 24p mode and do a normal pan by - it studders across the screen. Some say its suposed to look like this cause film looks like this (and in some cases it does) but in my sujective view I dont like it. The DVX100 does not have this issue. Pan shots in 24p have the kind of motion rendering I like. Anyway, Im considering an XH A1 but my biggest fear is that it will have the same frame judder that the XL2 has -when I want something like the DVX in high definition. |
Interesting, because the DVX100 and the XL2 share the *exact same* 24p implementation.
There should be some downloadable 24F clips around the time the XH cameras start shipping. |
I own both. Panning at the same speeds they look about the same to me. Subjectively...ehh...sure anything can be argued subjectively. Chris is right it is the same exact implementation. Factually speaking though it isn't possible.
You should take a look at XL-H1 clips. That will give you a good indication of what it will look like. The DVX and XL2 are progressive chip cameras whereas the XH-A1 is not. |
The two most likely reasons for "judder" in 24p or 24F are panning too fast when one is used to 60i, and leaving the image stabilization on when pan/tilting on a tripod. I've used both the XL2 and the XL H1. Pan and tilt behave just as one would expect at a given frame rate in both cameras.
BTW, this has been beaten to death, but since it was mentioned again...it doesn't matter that the sensor in the XL H1 and new XH cameras is an interlaced CCD block. We don't have footage yet for the XH cameras, but the H1 output is true 24fps that has slightly less image detail than the same camera's 60i, and more image detail than any other 24fps solution under $20k currently available. So as has been said many times, the chatter about the chip is just noise. |
Is it possible that you are using 24p in one camera and 24p A in the other camera? This would make each one look different. If the XL2 was shooting 24pA then yes it would be jerky compared to normal 24P. If your final output is some form of 24P the 24p A is actually the better form to use once you pull out the true 24p frames.
Shutter speed would make a big difference too. The XL2 defaults to 1/48th.
I just did a 3-camera music video shoot with 3 XL2s, in 24p, 1/48 shutter. No judder. Looks great, in fact, better than I expected under the low light conditions. When you're shooting in 24p, the viewfinder does look jumpy, but that is not in the footage.
I think it must be the differnce in the XL2s lens from the DVX lens. I think Ive been using the image stabalizer on the XL2 and should just turn it off all the time when shooting 24p. However, i use the OIS image stablizer on the DVX and dont get the same frame judder. Maybe I need to upload some video on here for you guys to look at.
Well, I shot with the stabilizer (when doing hand held stuff) on and no problem. Could be something wrong with your camera.
The XL2 has better OIS and should be off unless you are on the long end of the lens. The motion rendering, as noted, is exactly the same on both cameras.
ash =o) |
Are you saying you shoot with the OIS OFF all the time -unless you are shooting zoomed far in?
Also, I found this quote about the Canon XL-H1 off: http://www.dvinfo.net/conf/showthread.php?t=68020 "FEELING A LITTLE SHAKY Don't, I repeat, do not use the optical image stablizer (OIS) when the camera is mounted on something steady (bag or tripod). OIS introduces undesireable motion stuttering. Only use this when you have to." --- "MY FAST PANS LOOK LIKE BAD. If you are going to be recording in 24F mode, be very careful to avoid fast pans and tilts. You will get a stuttering motion that is very undesirable. This is a product of using 24 fps recording. The same problem is encountered by motion picture cameras. There are formulas on the Web about how fast you can go but I just know instinctively at this stage not to whip the camera around from north to south. Also, I don't care what anyone else says because I have seen this for myself, 24p video stutters more than telecined film. I have watched hundreds of films and I can see the motion is a little smoother than on a 24p video camera. The point is that it is all the more critical to avoid fast movement unless it is de-emphasized with a relatively slow moving object or person in the foreground to take the audience�s focus off the fast, stuttering part of your scene." |
Those quotes are related to 24P, not just the XLH, I could dig the exact same comments up about every 24P cam. Yes, I never use OIS unless I am over 8X zoom...
ash =o) |
With the same settings the cameras frame rate stutter/judder will look the same. |
don't use OIS for ANYTHING but a static shot that must be handheld. if you move the camera with OIS on then the OIS mechanism will track the motion till it reaches the edge of its travel then it'll snap back, over and over again and your result will be hideous.
you're not going to smooth out a moving camera this way; you have to use an intertial stabilizer/steadicam type thing for that (with OIS off). |
Ali, I have not found this to be the case with OIS on the Sony DSR250, the PD150, the DVX100a and the Canon XL2. I've done lots of moving around hand held shots with all those cameras with the stabilization on. IF, however, you try to make a move when the camera is mounted on a tripod, you will get the smearing effect which is no good.
I've noticed no different in the rendering between the two cameras on taped images. The only time I see a difference is when I am viewing what I am shooting through their respective viewfinders.
The DVX is WYSIWYG on its big LCD, the Canon is very stroby. One of a few complaints concerning my XL2 's viewfinder. |
| All times are GMT -6. The time now is 04:47 AM. |
