Re: canon XH A1s
Re: canon XH A1s
I still have (2) XHA1s cameras, mainly for use at performances, and weddings. Have looked at the XA25 as a replacement after trying one via CPS and realized that the AF on those is rather zippy compared to my XHA1s. I mostly use my 7D Mark II for promotional work, and everything except the ceremony when doing weddings.
For performance work, we run a firewire line into our MacBook Pros, and capture via QuickTime. Have done this for the past 4 years with no problems. I recently tried using my BlackMagic Intensity Shuttle Thunderbolt, going from the component out, and it works great. I can record ProRes LT now, and it has 4:2:2 color as well. I do hope to upgrade at least one of these this year. Will be trying out the XF200 this summer. Good to see a recommendation! |
Re: canon XH A1s
I use the HD-SDI out of the XLH-1 to feed the SDI in of the Samurai Blade. This provides 4:2:2 8 bit 1920x1080 HD. The component out, as I understand it, will only send out 1440x1080 HDV. |
Re: canon XH A1s
Apparently Canon will still service them (paid) through May 2018. They don't do basic clean checks for free (under CPS) anymore. Roughly $120 after CPS discount. |
Re: canon XH A1s
I love my xlh1a
Id like to use a ninja assasin to shoot slow motion frame rates. no hdmi however. is there a way to connect it up??? also pro res 422 would be an asset too plus the higher bit rate. any ideas? |
Re: canon XH A1s
| All times are GMT -6. The time now is 10:59 AM. |
