-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   iMac spec for XHA1s (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/506168-imac-spec-xha1s.html)
James Fryer March 17th, 2012 10:34 AM
iMac spec for XHA1s
Hi all,
I'm taking the plunge and upgrading from PC/Premiere to iMac/FinalCut and hoped any iMac users out there might be able to offer a quick bit of advice, please?
I will be using the iMac to edit XHA1s footage, as well as some 1080p footage from a GoPro camera I also use.
I'm currently looking at the 27inch 3.1GHZ version over on the right of this page (iMac - Desktop iMac Computer - Apple Store (UK)).
1. Will this be good enough to do what I want without tweaking the standard spec?
2. If I could upgrade one component from the standard spec, should I go for the processor, memory or graphics card?
Thanks in advance guys!
Cheers :)
Les Wilson March 17th, 2012 01:17 PM
Re: iMac spec for XHA1s
In priority order:
1) Processor
2) Graphics
3) Memory
My rule is buy the fastest processor you can afford. Memory can be added later. I don't know for sure but I doubt the graphics card can be upgraded in an iMac. Double check the model you pick has a graphics card compatible with Final Cut X
The A1s produces easy to edit HDV. It's you Gopro that produces AVCHD that needs horespower to edit it natively. Most people up-rez it to the easy to edit prores.
Ed Roo March 17th, 2012 09:08 PM
New iMac is Thunderbolt.
XHA1 is Firewire.
You will need one of the Thunderbolt to Firewire adaptors to input you video from the camera to the iMac.
James Fryer March 18th, 2012 04:16 AM
Les, Ed, many thanks for your help - really appreciate it.
Les that sounds good - I'm going to plump for the i7 and upgrade memory later on as you suggest. I've noticed that about the A1s footage - it's not bad at all on my PC, but the AVCHD slows up terrible.
Ed thanks for your note about this. I've had a read up on Thunderbolt as a new Apple input/output, however, it also looks like they're a normal FireWire input on the iMac too. See halfway down this page under 'Connections and Expansion': iMac - Desktop iMac Computer - Apple Store (UK)
Does that mean I wouldn't need the adapter?
Thanks again :)
Les Wilson March 18th, 2012 06:15 AM
That is a Firewire 800 port and will work fine. You will need a 6-pin to 4-pin cable if you don't already have one.
As far as AVCHD goes, most using FCP transcode it to prores for editing. That takes time and much more space. You may want to see if FCP X will do what you need as it has AVCHD support built-in.
Paul Elertson March 19th, 2012 12:01 PM
Not to derail the original thread, but here is my situation
imac
2.8ghz i5 quad core
ATI Radeon HD 5750
12gig ram
canon xh-a1
4-9 pin firewire cable
Final cut express
Now, the computer can easily handle editing all the footage I throw at it from an xh-a1 and a xa10. However, my one gripe is I have to use Imovie to import my xh-a1 footage.
Not sure if this is an FCP vs FCE thing, but just something to be aware of.
agreed 100%
please correct me if i'm wrong, but wouldn't James need a 6 to 9 pin cable for xh-a1s to imac?
Les Wilson March 19th, 2012 03:51 PM
Originally Posted by Paul Elertson (Post 1721844)
...please correct me if i'm wrong, but wouldn't James need a 6 to 9 pin cable for xh-a1s to imac?
You are correct. I had an XH-A1. I see they improved on that in the A1s. Sorry.
James Fryer April 18th, 2012 11:01 AM
Thanks everyone, and the 6 to 9 pin FireWire cable did the job - I'm glad I checked back here to get your thoughts before heading to the store.
I have to admit FCP is a little fiddly sometimes getting the xha1s tape running before it detects no capture, but nothing major to worry about.
Cheers!
