-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Custom Pre-set, Outdoor Setting (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/505588-custom-pre-set-outdoor-setting.html)
Ronald Jackson February 26th, 2012 02:28 AM
I've recently purchased a second hand XH-G1s as a (b) camera to go with my XLH1. I use a nanoFlash with both cams.
I need a Custom Pre-Set for out door settings, but I cannot open "number 17" in the CP library above.
I have tried duplicating the CP (also off DV Info) I use in my XLH1 but it is not the same in the G1.
I "auto white balance" in both cams by the way.
Ron
ps a nanoFlash a good albeit fairly expensive way of prolonging the life of these cams. provided they are ones with HD-SDI "out".
