-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   XHA1s HD/SD Component Connector (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/480731-xha1s-hd-sd-component-connector.html)
Alex DeJesus June 21st, 2010 01:13 PM
Is that a standard connector? Does anyone else make a shorter version of the cable that might be used with an on-camera monitor?
Panagiotis Raris June 22nd, 2010 02:37 AM
it is a D4 terminal to component cable; i just found one or two as i need to purchase them as well.
Opentip.com: D4 D-Terminal to Component 3'
Converters & Cables -- D-Terminal (D4) to Component Video Cable 3'
Alex DeJesus June 22nd, 2010 01:16 PM
Perfect! Thanks
Peter Manojlovic June 25th, 2010 08:24 PM
Alex.....
Do you know if it's possible to capture via component cables, and control the playback heads via firewire??
Thanks....
Alex DeJesus June 25th, 2010 09:09 PM
I capture with component through the Matrox MX02 Mini. I can control playback with firewire, but I do not record HDV timecode with component
