HV30 as capture deck for XHA1s?
The specs seem to match up, in fact, the HV30 exceeds in Megapixels...
Does anyone use this model to capture tapes from the XHA1s? I have a small dv consumer camcorder that I have used for several years for my XL1s, so it is just used for recording only. Any other recommendations? Thanks! |
The HV cameras are the perfect capture cams for the Canon XL/XH series cameras.
What's most important is that they read the Canon progressive F modes, so they will capture any mode that your camera will shoot. Hope this helps. |
I use the HV30 to capture from my XH A1s, no problems to report.
all righty,
thank you guys! |
HV30 as capture deck for XHA1s (is this for play back?)
hi guys, could someone educate me as to this technique? Is the HV30 used as a playback deck? I'm looking at finding what else I need as to not use my XHA1 for play back, or am I missing the point here?
the idea is to save the wear on the XH heads, so it would be advisable to use the HV30 as both a capture and playback deck.
or pick up a used firestore, datavideo DN-60, or sony mrc1 firewire recorder and go tapeless. |
The idea isn't really to "save wear on the heads" -- you could use the XH for playback every day and not adversely affect the tape playback heads. The notion that you shouldn't use the XH as a playback deck is a complete myth. Instead, the real advantage of using an HV camcorder as a playback deck is to keep your XH free for shooting -- because it's not earning if it's not shooting.
perhaps, but i had to pay for the heads on an old minolta camera to be replaced/serviced, and it was not cheap.
ive gone tapeless anyways, so its a non-issue for me. |
Thanks Chris, excellent point. Panagiotis, I didn't even think of tape less when I was shopping, Getting over the 1H limit would be great for some jobs, I will definitely keep an eye out for solutions as they are posted. Thanks again guys.
The HVs are no slouches as far as recording their own footage either.
HDMI port?
I don't know how true this is, but I saw in another forum post that the HV has HDMI output. That would be good if you use a box like the Matrox MX02 for capture and you don't want to use firewire. If anyone can verify this, please let me know.
The HV30 MiniDV does have HDMI.
