-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   shotgun MIC install , ch1 XLR or Mic in? which (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/478961-shotgun-mic-install-ch1-xlr-mic.html)
Chris Wysocki May 19th, 2010 05:02 AM
so , i finally got a shotgun mic for my xh-a1. On the shotgun mic end is an xlr , should i connect it to my ch1 xlr or to the mic input on the side of canons(mic) ontop of the camera? would going into the ch1 xlr be a better choice since xlr is grounded. better for less ground noise.
Chris
Annie Haycock May 19th, 2010 05:18 AM
Use the XLR plug and go through the menu to change the audio input to XLR. If you connect to the "mic in" plug, you need an adapter - an extra connection that may affect the sound quality.
Chris Wysocki May 19th, 2010 05:29 AM
thanx Annie!!!!! for the ultra quick reply!!!!!! and info
