ND On/Off warnings
Is it true that the A1 can warn me to use the ND filter by flashing ND On and warn me to switch it off by flashing ND Off? My A1 doesn't warn me for ND.
Doubtful, I have yet to see such a warning on the XH-A1, nor is there a menu option for this. My suggestion, shoot in shutter-priority mode and allow the camera to adjust the shutter speed when you've got too much light (and forgot to set your ND filter). Better yet, do as the pros do, set your iris manually and use zebras to let you know when you're overexposing important parts of the image. This gives you the benefit of a f-stop readout on the LCD. If you find yourself closing down to f-9, its time to up the ND.
The manual says there's warnings, and i've received them myself...
Of course, these are extreme situations, in where you're Exposure lock might be set, and have unwittingly opened up the ND to the first setting...But it's definately not a common occurence..Your Zebra stripes would be the first hint of trouble... |
See page 39 of the instruction manual.
Also be aware that several other pages have "Precautions related to the camcorder operation." entries which refer to the ND filter. The easiest way to find all these entries (and the entries for any other subjects for that matter), is to download the manual in pdf format and use "Find" (under the Edit menu). |
Hi
I'm more or less sure that ND warnings never will show up in M (Manual) mode. I use M most of the time but sometime I've used other modes and seen the ND filter warning flash. Side 31 in the manual says: "When using a recording program other than M Manual and if the AGC switch is set to ON, the following displays appears: " followed by a list of different ND warnings, either to activate or deactivate ND filters depending on what the camcorder think is the best. Regards, /Bo |
Now that you mention it, I think the XH-A1 does do that. I remember having that experience a long time ago when I first got my XH-A1 but since I rarely trust the cam's auto settings, I turned it off. And now I don't know how to turn it back on because I would never use it anyway. Just extra stuff on the display that makes the image harder to see.
Yes, warning is true. But it is warning only if ND filter is not right switched.
Nd
The camera will flash ND when it needs it - and flash in red when it must be reset or turned off. Be careful of shooting in very bright sunlight without the ND - or ignoring it. See the note on blurred images related to use/non use of the ND. ( Mode was auto, auto gain, auto iris )
I have had this problem show up on a shoot where the producer didn't want any tapes viewed until they were captured .. Problem - shoot was in Wyoming ; producer in Kentucky didn't look at the footage until 6 months later. There were 3 shots out of 6 tapes that were blurry due to this issue - but they could have easily been THE ones I needed. |
I always follow the ND flashing icon with the XH-A1. I'm not sure if it's my camera, if I have ND filter on, in bright day light, there're more visible noise. What should i do? Should I try resetting the camera?
Personally, i'll hit the Exposure lock button to tell me my current Fstop under the current lighting conditions. F4.0 or F5.6 is the sweet spot..If it's too low or high, i reset my HD filter and redo the above for good measure...It's just as fast and easy for my EVF+Zebra stripes tell me approximately where i should be...
As for noise, i've noticed that the footage looks a bit softer with the ND filter set to max. Regardless of exposure..Perhaps it's just me. |
Oh it's not just you. I have such problem too. Once time I did a wedding in a bright sunny day. The footage got very noisy.
I see this sometimes as well, but I put it down to the camera getting hot in the Singapore sunshine and degrading the sensor operation. Haven't done any proper tests on this though.
Richard |
Soft and/or Noisy Footage
Hi Richard, Taky and Peter,
The first paragraph under the heading "Using the ND Filter" in the instruction manual reads: "When recording in bright surroundings, the camcorder will set a small aperture value and the picture may appear blurred. Turn the ND filter on/off according to the screen display." This section then goes on to say in part: "When using a recording program other than M Manual and if the AGC switch is set to ON,....:" So, the softness (looks slightly out of focus) can come from not turning the ND filter on. As to the noise, since the ND filter warning only operates when recording in other than Manual and the AGC switch is set to ON, then the noise may be coming from the AGC setting you have previously input. In any case, in very bright sunlight the maximum inbuilt ND filter may still not be enough to cope with the bright light, so you might consider investing in some external ND filters so that you have more effective control of the camera when using one of the automatic modes. It does go on to say in the instruction manual, ""If you have no external ND filter available, use the Tv mode and set a high shutter speed,...." which might alleviate the problem, but still leaves you in the situation where the settings used automatically by the camera may still not cope effectively with the bright light. Hope this helps. Colin |
Colin,
Thank you so much for your insight. I'm just glad there're so many knowledagable people here. I will kick away my bad AUTO mode habit start practicing using Tv mode you suggest. Taky |
