-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   canon xh a1 - shot in 24f mode when captured its 29 frames second (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/239942-canon-xh-a1-shot-24f-mode-when-captured-its-29-frames-second.html)
Dave Morgan July 29th, 2009 02:40 AM
canon xh a1 - why is a tape i shot in 24f mode showing up as 29 frames per second and playing faster? how can i fix it.
Howard Churgin July 29th, 2009 04:37 AM
How did you setup the project file? You must tell it which frame rate you are using or pick the appropriate template: i.e HDV 1080 30fps 60i.
I don't think you can change the frame rate once set up. You probably should start a new project at the correct frame rate and import the clips already captured from you hard drive and see if that works.
John Stakes July 29th, 2009 05:37 AM
given the quirkiness of some NLEs, your best bet is to just start fresh. Set up a project using the DV24p preset and capture to that timeline. If you shot in HDV, then you need to download the proper preset from Adobe.
JS
Sean Finnegan August 3rd, 2009 04:59 AM
Double check your sequence settings. You should always make sure that your NLE sequence settings match the format your footage is in. For instance, if you shot footage at 60i and your sequence settings are set for 24p, it'll look wonky when you drag it onto the timeline.
Mike Flynn August 7th, 2009 10:23 AM
Also, if you set it to downconvert thru the camera and capture to SD, all frame rates are outputted as 29.97.
