-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Hey guys i'm trying to buy a letus extreme 35mm (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/237426-hey-guys-im-trying-buy-letus-extreme-35mm.html)
Arthur Abramov June 16th, 2009 09:36 AM
i'm using the a1, i know that i need 72mm diameter thread but do i get the 45cm rod support system for the letus..?
Thanks guys.
Ken Wozniak June 16th, 2009 08:39 PM
If you're asking if you need the rails, the answer is a definite "yes". It should all be available as a kit. Where are you buying from?
Arthur Abramov June 18th, 2009 12:29 AM
Probably B&H , I would need a case also wouldn't i?
Ken Wozniak June 18th, 2009 10:42 AM
Yes. Letus makes cases specifically for their adapters. B&H sells those cases.
I've done a lot of research on the lens adapters, but have not been able to pull the trigger yet.
Be sure to post some footage once you start shooting with the Letus.
Christopher Warwick June 18th, 2009 11:21 AM
Personally, I'd go with the 60mm rods, not 45. It depends what you're doing, sizes of lenses etc. But if you want to upgrade later and need more space to load stuff on your rails, you aren't going to have enough room with 45mm.
I'm glad I chose the Proteus Cinevate system with 60mm rods.
Chris
