-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Capturing xha1 60i format with HV30 (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/234305-capturing-xha1-60i-format-hv30.html)
Travis Fadler April 29th, 2009 02:05 PM
I'm capturing xha1 60i footage with an HV30 which doesn't have a 60i mode. The footage looks good but would it be any different if I were capturing from the xha1? Using firewire.
Joel Peregrine April 29th, 2009 03:11 PM
Hi Travis,
There would be absolutely no difference if you're capturing HDV. There isn't any difference in the captured file quality, structure or how the computer will see it. The only thing I haven't tested is whether or not there is a difference in the quality of A1 footage when capturing with either the HV30 or A1 and you're downconverting it to SD. I'd guess they are the exact same quality in that case too, but I can't say for sure.
Bill Pryor April 29th, 2009 06:22 PM
Doesn't have 60i? That's what it shoots, as well as pulldown 24p and 30p.
Travis Fadler April 29th, 2009 07:29 PM
The menu of my HV30 only shows 24p and 30p, no 60i. I use it as my b camera and deck, should probably RTFM!
Brian Lakusta April 29th, 2009 10:54 PM
I have a HV20 but not used it since last year. I have 60i in it so think you should have it with a HV30. There is a setting to change to go from 24p (30p-I don't have ) to 60i so read more... you should have 60i too.
But I could be wrong.
RTFM ... lol.
Bill Pryor April 30th, 2009 10:02 AM
It does. As you said, recording mode can be changed in the menu.
