-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Sky detail (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/144807-sky-detail.html)
Wil Vermeesch February 28th, 2009 09:26 AM
Sky detail
Hello,
Perhaps a stupid question but:
Setting the Canon XHA1 you have the possibility to set the Sky detail on SOFT or OFF.
Are you using this setting, why and when because I have the feeling this setting is given a non detectable effect.
Thanks in advance for your reply
Wil
Wil Vermeesch March 1st, 2009 02:49 AM
Nobody experience with this?
Nic MacDonald March 2nd, 2009 04:35 PM
It's not a particularly obvious effect. Basically, because blue skies can be a bit noisy, the XH can provide in-camera noise reduction on just the blue areas of the frame. If you're outside on a nice day, you're lining up a landscape shot and you're not in any particular hurry, you might want to jump into the menu and activate this function.
Tripp Woelfel March 3rd, 2009 07:10 AM
Nic... Great insight. It sounds like you've used it some. Can you comment on what it does to the details in clouds?
Nic MacDonald March 3rd, 2009 10:28 AM
In fact, I live in England where there hasn't been a blue sky in living memory so I haven't made much use of it, but in theory it shouldn't do anything at all to the clouds - only to the blue areas of the frame. Perhaps someone in an area with a more pleasant climate could comment on this.
Jack Walker March 3rd, 2009 12:59 PM
July 2007... beautiful blue sky, and virtually tropical temeratures and humidity. And the theaters don't have air conditioning.
Nic MacDonald March 4th, 2009 05:08 AM
So maybe I have a bad memory. :P
I didn't shoot anything outdoors around then though, so...
Jack Walker March 4th, 2009 10:00 AM
It was so hot, I expect you were on holdiay!
