-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Recording direct to SD card? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/143043-recording-direct-sd-card.html)
Mick Mearman February 4th, 2009 09:59 AM
At the risk this question has been asked before, as there is a switch on the A1 to record still pictures to either tape or card, it doesn't seem too far out to me that a firmware update couldn't enable video recording to SD card which would be great without having to attach external units?
Mick
Battle Vaughan February 4th, 2009 10:06 AM
video records to tape, stills to the card. /Battle Vaughan /miamiherald.com video team
Alan Craig February 5th, 2009 03:34 AM
It's a nice thought but how much video could be stored on an sd card.
Alan
Mick Mearman February 5th, 2009 05:01 AM
Alan
Hello Alan
With the new SDHC cards up to 32GB, I just thought that when Canon designed the A1 there were only the low capacity SD cards available so there wasn't much point, but now with the likes of Panasonic HMC 151 which will only record to SD and others that have both, if an update would allow A1 users to do the same?
Mick
Chris Hurd February 5th, 2009 07:46 AM
The Canon XH camcorders are compatible with SDHC cards, and as demonstrated on a lot of AVCHD camcorders, a 16GB or 32GB SDHC card can hold a couple of hours worth of HD video... in fact, much more HD video than can fit on a standard 60min tape, and at just as high quality as HDV, if not better.
The problem is that a "firmware update" is not going to magically enable an HDV camcorder to become an AVCHD camcorder. You're looking at significant internal hardware changes -- it's a lot more than just firmware. Hope this helps,
Steve Sobodos February 5th, 2009 06:44 PM
Alan
To record on a SD card you need to get a Sony HVR-MRC1.
(see the thread here : Awesome news for canon users - The Digital Video Information Network)
As for time, the 32GB 133x SD card records about 140 minutes of HDV.
Steve
Chris Hurd February 6th, 2009 09:42 AM
The above post is incorrect -- the Sony HVR-MRC1 does *not* record to SD (Secure Digital) cards. It records only to CF (Compact Flash) cards. There is a huge form factor difference between these two type of memory cards, so be aware.
On a related note, there is no such thing as an SD card with a capacity of 32GB. Memory capacities that high are found in SDHC (Secure Digital High Capacity) cards. Hope this helps,
