Using Macbook laptop as location monitor
Can I use a Macbook Pro laptop computer as a monitor when shooting with my XH-A1?. I do not want to capture to the laptops hard drive, I simply want to be able to monitor my shot without having to look at either the cameras eyepiece or it's built in monitor. What, if any, software would I need and what cables for the connection? Thanks for the input.
Rich. |
Haven't done it recently but you can use iMovie (or Quicktime Pro if you don't mind the aspect ratio being wrong for 16:9). There will be a timelag though - that can be a pain. That's assuming a FireWire connection (6 pin Mac end 4 pin camera end). You can use other outputs (composite or component) but you would need extra hardware.It might get rid of the time lag though.
I have done that with a 17" MacBook Pro. Open iMovie, expand the window to full screen, and it works great. The aspect ratio works with 16:9 automatically, assuming you have the latest version. As mentioned, there is a lag, but if the purpose of the monitor is so someone else can watch, log takes, etc., then that is OK.
| All times are GMT -6. The time now is 01:39 AM. |
