XH A1 24F workaround with Avid Media Composer 3.0
Hi everyone,
I'm sure this topic has been covered, but I'm having a bit of difficulty and am in a time crunch. As is well-known, Avid Media Composer 3.0 doesn't capture 24F mode with the XH A1. I was able to capture my 24F 1080i footage via HDVSplit to my computer. However, when using MPEG Streamclip, the captured footage was very choppy to play. When I converted it to DNxHD, AVID accepted and converted the file, but there was no picture (just a white screen). What do you think the problem is? Thank you in advance. Kareem P.S. I also posted in the Avid editing family thread, but have yet to receive a response. Sorry for the double-post. |
Sounds like it let you render but the codec didn't accept the original data and just rendered blank. I use Tmpeg Encoder and had no problem converting the m2t files to Quicktime in DNxHD which avid worked fine with, so not sure what happened unless you need to reinstall the codec?
regarding the Avid 24f issue, I don't know if this works for NTSC but I am in PAL land and I simply capture in 50i mode and then just change the project to progressive. The reason it works is because even though I filmed 25f it records in an interlaced format (there is a better explanation). So maybe you could try 60i as supposedly it still records in 29.9 (even though to actual frames are in 24f) otherwise in future shoot in 30f and that should work. |
Also, MPEG streamclip worked with the m2t file. However, it only worked for the video. My problem was I wasn't converting to a Quicktime DNxHD (I was trying AVI). So now I have video which looks great, but no audio. What should my settings be when converting audio? Thank you for your help. |
