-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   I need Help my camera just died (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/140312-i-need-help-my-camera-just-died.html)
Alain Mayo December 26th, 2008 07:05 AM
Hi and Merry christmas to all
Yesterday while I was filming my camera just went dead, and I know is not the battery because it was charged and after it happened I recharged it a little more just in case but I didn't have any luck, It won't turn on. Have this happened to any of you before?. Any suggestions before I call canon customer service?
Colin McDonald December 26th, 2008 07:46 AM
Sounds like the dreaded Standby Mode levers (NTSC pdf manual page 152 - Troubleshooting)
There's one on the back of the camera and another on the top.
Bill Fredette December 26th, 2008 07:46 AM
Sorry if I'm suggesting the obvious, but it's happened to me. Are you sure the "Standby/Lock" switch on the back of the handgrip didn't accidentally get pushed to "Lock?"
Hope you find the trouble.
Bill
Alain Mayo December 26th, 2008 08:01 AM
Bill
That's the first thing I checked, the standby/lock switch in the back of the camera where you press Record.
Alain Mayo December 26th, 2008 08:02 AM
Hey which one is the top one? I allready know of the back one where you press record and that one is where it should be.
Bill Fredette December 26th, 2008 08:10 AM
Check page 13 of the manual (it's quicker than my trying to describe the location).
Alain Mayo December 26th, 2008 08:16 AM
I'll check but I don't think is that. thanks
Tripp Woelfel December 26th, 2008 09:12 PM
Did you try running the camera on house power instead of the battery? It is possible, but not likely, that the battery shorted itself out. It does happen but it's very rare.
James R. Leong December 26th, 2008 10:32 PM
Maybe try ejecting the battery, clean the contacts and reinsert. Sometimes if the battery is not properly seated, there is no power.
Steve Wolla December 26th, 2008 11:09 PM
Try it with the AC adapter--will it turn on then? If so, you have a defective battery. Try it with another battery, see what happens.
If you have dropped it, (the battery that is) that can sometimes damage the battery's internals so it ceases functioning.
Jarred Gastreich December 27th, 2008 01:37 AM
I had the same problem with my 2 day old XH A1. It simply wouldn't turn on. I called Canon tech service and they told me to hit the reset button (which is located under the LCD). That didn't work so I exchanged it for a brand new one with my dealer.
I'm thinking it had something to do with the Firewire being plugged in, because that is when it stopped working. The firewire 6pin slot in my computer where I used to plug it in will never be used again because of fear.
Bo Sundvall December 27th, 2008 05:25 AM
Hi
Does it work in VCR mode, as a player?
Regards,
/Bo
David Hodge December 27th, 2008 06:50 AM
I have a Sony EX1 and it has a lithium battery that helps keep the camera alive.
You might consider checking to see if there is a lithium battery that has run down and is keeping the camera from coming on in order to preserve the settings and time on the camera. The Sony cameras I've had, and my mac book pro as well, will go into hibernation to save information on the computer. So, please check to see if you have a lithium battery on the camera somewhere. Replace it.
Even if it doesn't work it may be cheaper and faster than taking it in for servicing.
Give it shot and let us know what happens?
d-
Alain Mayo December 29th, 2008 01:26 PM
Thanks guys for all your replies but None of the suggestions worked, I sent the camera to Canon. I'll let you guys know the status.
Mikey Williams December 29th, 2008 09:42 PM
You may have just tripped the master fuse. That happened to me last February with my XL2. Pretty simple fix, has to be sent in tho. It cost me about $180 at a Canon authorized repair facility in Canada.
