-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Is 25f the same as 1080p (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/138167-25f-same-1080p.html)
Bo Sundvall November 21st, 2008 07:04 AM
Hi
The Canon XH-A1 (PAL) can save either 50i or 25f video. As I understand from reading several posts here, the 25f mode saves 25 frames per seconds encapsulated in a 1080i signal. I also understand that 25f differs a little from a true progressive mode but as the differens is so subtile it really doesn't matter and 25f should be seen as a progressive mode.
Now my questions: Is it correct to say that the 25f mode is the same as 1080p or am I missing something?
Regards,
/Bo
Chris Hurd November 21st, 2008 07:08 AM
Yes, you can refer to 25F as 1080p25 or 1080/25p (because that's what it is).
