-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Shotgun Mic Holder Screw (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/137999-shotgun-mic-holder-screw.html)
Jonathan Pears November 18th, 2008 01:12 PM
Hi All
I need some help with the actual screw that closes the shotgun mic arm. I did a expo shoot and someone in the crown knocked into the camera when the screw was half done up. It made the screw slip a thread and i only found out when i got some.
I tried to use some pliers to remove it, as it was stuck like concrete in the arm. The screw then broke in 2! I'm a mechanical engineer by profession, and this thing broke easy!
So i now have to drill out the old screw half for a new one. Anyone know where i can get one of these screws?
Hubert Duijzer November 19th, 2008 04:44 AM
I had a similair problem with the screw. It messed up the thread a little, so i decided to buy a new mic holder, wich includes the thumbscrew.
As you said, it's not the strongest part of the XH...
Jonathan Pears November 19th, 2008 07:42 AM
Where did you get the mic holder from?
Hubert Duijzer November 19th, 2008 07:54 AM
I'm from the Netherlands ;) You don't want to pay the shipping costs to your side of the water.
You better contact your local Canon department.
