-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   One more piece of advice needed.... (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/128758-one-more-piece-advice-needed.html)
Derrick DeWilde August 26th, 2008 12:35 PM
I don't know what switch I hit, but I was recording outside this weekend and noticed a "NDFILTER ON" flashing in my screen. How did this get turned on to automatic...is it because I had my gain set to Auto (the switch next to the white balance?) I was filming in A (the one with the box around it) - is that the reason?
Any help on this would be great! I am thinking it is because I am in "A" mode...but should also probably turn my AGC in the off position along with my white balance?
Brian L. Allen August 26th, 2008 01:52 PM
You have the ND filter turned on, switch located on the lens, 3 position switch off, ND1, ND2. Auto Gain should always be off unless you want the grain that will come with it.
Bill Watson August 26th, 2008 02:29 PM
If 'ND ON' is flashing the camera is telling you to use the ND filter.
This only happens when you have the AGC switched to 'ON'.
Derrick DeWilde August 27th, 2008 02:54 PM
Gotcha... will turn the AGC to off! That was my problem! Thanks a TON! Easy question for once!
Mark Fry August 28th, 2008 10:05 AM
I have, on at least two occassions, caught the ND switch part-way between settings. "ND on" flashes in the viewfinder in red. (AGC switch was "off" both times.)
