-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   slow motion (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/127726-slow-motion.html)
Nagisa Kodama August 9th, 2008 01:17 PM
slow motion
I usually shoot 30F and am thinking of using the footage to do slow motion in post.
I know that 60i would be better for that, and I have no problems with that, but I don't think final cut likes me mixing frame rates...
Bill Thesken August 10th, 2008 09:45 PM
Don't know about final cut, but I mix frame rates all the time in Vegas. Slow motion looks great in 60i, but terrible in 30f and 24f. I use the 24f for interviews, and 60i for action. Although I did a couple of interviews recently in 60i and could not really tell the difference. It was the pace of the interview, and the subject matter which caught the attention more than the frame rate.
Jonathan Shaw August 10th, 2008 10:26 PM
In final cut you can use the media manager to match / alter frame rate etc. I generally shoot 50i but have mixed in 25F no problems.
Paul Whittington August 11th, 2008 12:08 AM
Hey Nagisa, if you're using Final Cut 6 and have Final Cut Studio 2 and want the best slow motion possible then use Motion - it will give you the best results no matter which frame rate you're using.
David McGiffert August 11th, 2008 12:37 AM
Paul,
I totally agree.
If you want great slow motion use Motion.
The results are beautiful.
David
Bill Thesken August 15th, 2008 03:21 PM
Can anyone provide an example of 30F slow motion?
My experiments look chuttery. Only 60i w180-210 shutter looks silky smooth for slowmo.
Paul Whittington August 15th, 2008 06:55 PM
Hey Bill... You know, I never use either of the F-modes with the A1 - with my A1, even at normal speed, those modes looked very choppy so I'm not surprised when you say they look that way in slow-motion as well. I guess it's best to stick with 60i if you can.
Adrian Stucker August 21st, 2008 03:27 PM
slowmo
The best slow motion I've achieved is shooting 60i, shutter <100. Capture, then bring into after effects. Right click the footage in the project manager, and select "interpret footage" Using "upper fields first" option, and conform to 23.98 fps.
This effectively separates the field into 60fps. Then using the "Time Stretch" you can stretch up to 250%. Make sure motion blur is off. results are breath taking.
Jo Potts August 21st, 2008 03:56 PM
If you want brilliant slow motion and are using FCS2 then chuck it into motion and set the retiming option to optical flow - it will take a little while to analyse your clip (which only needs doing once, no matter how many times you change the speed afterwards) and produces some stunning results - no matter what frame rate or shutter speed (i've used it on some pretty poor footage and made it look fairly decent!).
Obviously if you don't have Final Cut, then ignore this!
It's worth noting that if you only want it on a small section, then make sure you don't send a whole clip to motion. I'm not sure whether it analyses the whole file (as it sits on the disk) or whether just the in and out points you've sent it - but either way, you don't want to waste your time...although it does work in the background so you can carry on with other stuff.
Mike Flynn August 21st, 2008 06:12 PM
I have been struggling with slow motion for the past couple years now. I love the look of 30f, but I generally shoot high action sports (motocross, etc) and just slowing the footage down using Final Cut produces a stuttery image most of the time.
This year I switched to 60i for shooting motocross, but I absolutely hate the look of 60i on a television. Good thing most of my work is for the web.
I recently shot a wedding using 24f. I was a little worried about how the slow motion would turn out, but I think it is going to be wonderful. Just 10 minutes ago I ran this test on a piece of footage: http://magic-mike.net/temp/weddingslowmo.mov
My workflow was: Twixtor Pro plug in, slowed down to 28%. Then added some SmoothCam (never even used SmoothCam before so I don't know what I'm doing). I am pretty happy with that result, especially since it started at 24f. Obviously there is very little movement in the shot, which helps to create a smooth image. With high moving images, Twixtor will leave you with warped areas that aren't useable. I would recommend trying Twixtor if you think your footage isn't too high action.
EDIT: Also wanted to add that I agree with the others that have said it, Motion produces far better slow motion than Final Cut Pro. Even just using a Motion Blend as opposed to Optical Flow with leave you with much better results.
Adrian Stucker August 25th, 2008 10:05 PM
slow motion
Remember if you shoot 60i you can make beautiful slow motion, then render you entire project to 24p, you can always go down, but never up.
Here is an example using the XH-A1 with 60i slow motion. I used a shutter of 1/60 and it produces a blur, for this project I like it.
But generally if you shoot above 1/100, it will be very crisp.
Mike Skates Downtown on Vimeo
Pavel Tomanec August 26th, 2008 04:45 AM
Vertical resolution 24/25f versus 50/60i
Thanks for sharing your video. It's quite OK.
I wonder though about the issues regarding vertical resolution. I keep hearing that Canon's frame mode is 15-20% less than full resolution (1080 pixels) but the 50/60i is 1080i lines interlaced so theoretically after de-interlacing you end up only with 540 lines!
For film transfer or Blue Ray this would be definitely insufficient. Would people kindly shed some light on this issue again?
I am especially interested exploring the possibilities/limitations in relation to slow motion/fast motion. I am happy to hear about the quality of slow motion in Motion. I must admit that I was not very happy with the slow motion produced by Final Cut Pro 6. Thanks for sharing the knowledge, much appreciated.
Many thanks,
Regards,
Pavel
Jonathan Levin August 26th, 2008 07:31 PM
Greetings.
Back in the day when I was shooting film, going to anything above 24fps, like 30, 60, 100fps and so on is what would give you the effect of slow motion, although you had to adjust the aperature to a larger f/stop. The film passing through the gate of a projector is still going at 24fps, so the higher "shutter speed" on the camera is what produced the slo-mo.
On video, isn't it the same? Video is "traveling"at (roughly) 30fps, it's being "projected" (tv, monitor, etc) at 30fps, so it seems that just changing the shutter speed (and adjusting the aperature accordingly) of the video camera to say 60, or 80 fps would just automatically give you the desired slo-mo effect. No? I still get confused by the differences or simularities of "60i" which translates to 30fps. I understand that because of interlace, each frame is actually two frames, if you will.
But this is a seperate entity from the actual shutter speed of the camera, right?
Thanks for all this info.
Jonathan
I think this was explained
Bill Pryor August 26th, 2008 07:46 PM
Correct. Shutter speed has little to do with slow motion. Faster frame rate gives you real slow motion, just like in film. However, if you don't have a camera with variable frame rates, you can approximate a slow motion look with software. It's never going to be as good, but you can slow a shot down up to a point without it looking too jerky.
Adrian Stucker August 26th, 2008 07:52 PM
In your first paragraph I think you are confusing shutter speed with frames per second. The shutter is how often the camera lets light in.
The frames per second are not affected by the shutter.
For example if you are shooting 24fps, and the shutter is 1/250, the frame is exposed every 1/250 of a second, but not more frames are being created.
does this help?
Pavel Tomanec August 27th, 2008 03:15 AM
Vertical resolution explained
Greetings.
I'd like to take back my initial query regarding the vertical resolution in my previous post.
Today I found thread more than a year old which may shed some light on it.
If you are interested please go here:
http://www.dvinfo.net/conf/canon-xh-...est-mtf50.html
Another informative discussion is here:
http://www.dvinfo.net/conf/canon-xh-...er-dvfilm.html
Thanks.
Pavel Tomanec August 27th, 2008 03:20 AM
It helps
does this help?
Thanks, yes helpful. I guess the bottom line is to stick to 24/25f for my work (I like documentary with narrative feel) and for planned slow motion change the frame rate to 50/60i, shutter ideally at about 1/100-120.
Does anyone has any experiences with shooting for fast motion with XH A1... just asking before 'pulling the camera trigger'.
Pavel
Jonathan Levin August 27th, 2008 08:59 AM
Hi Bill and Adrian.
Thanks for your reply. I guess where I'm confused is say if there are 24 or 30 fps second going through the camera, that means that each frame is "exposed at a 1/24th or 1/30th of a second= shutter speed.
Adrain, I think the shutter speed example you give would be closer to 1/24th sec, not 1/250. (One second of 24fps film divided by 24 frames= 1/24th sec.)
If you shoot 100fps, than each of the 100 frames is exposed for 1/100th of a second, shutter speed.
In the above samples, it takes either 24, 30 or 100 frames to make one second of moving footage.
I also assume, and correct me on this if I misunderstand, that each "frame" is exposed imediately following the last frame like this: _______________ with no lagtime that might be like this: _ _ _ _ _ _ _ _
Bill, without sounding really off here, is it possible to even do slow motion WITHOUT shooting at a higher shutter speed in a video camera?
Thanks for your patients.
Jonathan
Denise Wall August 27th, 2008 06:01 PM
Ya know, I have Final Cut Studio 1 with FCP 5, etc., and as far as I can tell, there is no slow motion function in that first version of Motion. How can that be possible in a program called Motion!? Am I missing something?
I've been with FCP since FCP1. I've been through a lot of upgrades. I'm waiting for FCS3 before upgrading from FCS1. It's more expensive than it used to be with the whole set now.
I've been using FCP5 for slow mo with okay results at 60i but would love something better with the software I already have.
Bill Pryor August 27th, 2008 09:13 PM
Jonathan, you're still confusing shutter speed and frame rate. Shooting at a higher shutter speed will not give you slow motion. Shooting at a higher frame rate will. But the only relatively cheap cameras that do that are the HVX200 (up to 60 frames per second) and the Sony 1/2" chip EX, which also goes to 60 fps. Unless you use one of those cameras, or a film camera or more expensive camera that does variable frame rates (like Varicam), the only thing you can do is do it in post. There's some software called Twixtor that allegedly helps give better slow motion than standard NLE software.
Jonathan Levin August 28th, 2008 10:30 AM
Bill.
Thanks for working with me on this. I moved this topic back to:
http://www.dvinfo.net/conf/open-dv-d...rates-etc.html
See my response there.
Jonathan
Gert Kracht August 31st, 2008 05:44 AM
Hi Jo,
I'm working on a MAC Pro with Final Cut Pro. Last week I saw a clip on VIMEO with brilliant slow motion footage. All made in Motion and because I have some very nice footage i want to bring down in slow motion I tried to do the same thing.
I got the speed down to 25% and the exported .mov clip has been generated after waiting quite a few hours. (more then 10 hours....) The result was indeed very good. But, after that I tried to bring the clip in to FCP again and it kept on crashing. So, no luck there for me.
I was wondering if you could tell us about the workflow you use in motion to make slow motion footage. And can you re-import the new footage in FCP?
I'm VERY curious about that.
Thank you very much in advance,
Gert
Pavel Tomanec August 31st, 2008 06:27 AM
Troubles in Motion
Hi,
I second to this - issues with Motion, last night I spend several hours to export from FCP 6 to Motion 3 footage for slowmo and because I do not have installed contents so it seems there was no possibility work with it at all. Or I am doing something wrong...
I tested demo of Twixtor 4.5 but the rendering time is a quite killer - couple of minutes = several hours. Will test more and share my findings (will take sometime).
Thanks.
Pavel
