-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   4 audio channels with XHA1 - ?!? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/126771-4-audio-channels-xha1.html)
Ozan Biron July 27th, 2008 03:52 PM
how do i record 4 separate audio channels into the XHA1? Somthing like this?
http://www.ozan.ca/XHA1.JPG
Can each XLR input even read as a stereo channel? If I record from 4 separate mic's sources into my MIXER and into input 1 and 2.... how would i extract each channel as a mono channel in Premiere? Premiere only shows the HDV source as a single stereo layer.
eh, this is so confusing.
Jo Potts July 27th, 2008 04:53 PM
XLR input aren't stereo channels. The only way to get 4 channels of audio into it is to go via a mixer first, but then you won't be able to control each individually - only a maximum of 2 (depending on your setup).
Don Palomaki July 29th, 2008 06:43 PM
You cannot record 4 channels at the same time, only two (and they can be stereo if your sound source is so configured).
While you can record 2 channels in 12-bit mode, you cannot dub sound to the remaining two 12-bit mode tracks.
However, FWIW, the XL does allow 4-channel recording in 12-bit/32 kHz mode.
