-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   FCP 6 video settings (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/126049-fcp-6-video-settings.html)
Richard Lozano July 16th, 2008 07:19 AM
I'm very new to FCP. I have some footage in the XHA1 at 24fps. I'm a little confused as to the settings I should use for the Sequence Preset. Right now I have it set for Apple ProRes 422 (HQ) 1920x108024p. Is this correct?
I did have it set for 60i, but when I exported it to Quicktime and compressed it for Vimeo, it looks pretty jumpy. I think I had the framerate messed up. Thanks.
Benjamin Hill July 16th, 2008 07:45 AM
Variables: did you shoot with regular or advanced pulldown ? did you capture the footage as ProRes or as HDV? what settings did you use on the QT export?
Bill Pryor July 16th, 2008 07:51 AM
If you shot HDV 24F, all you have to do is use the HDV1080P24 Easy Setup. Make sure your sequence settings match. If when you drop a clip into the timeline and it wants to render, then they're not matching. Do it right and it will not need to render for viewing and editing but will when you export the final program. When you do export, do not deinterlace, since it's not interlaced when captured and edited.
Richard Lozano July 16th, 2008 10:58 AM
Thanks. I did deinterlace and I also had the sequence set at 60i instead of 24p. I'll change those two things.
Richard Lozano July 19th, 2008 10:00 AM
This feels like kind of a dumb question, but sometimes when I capture, a window pops up and I can set the in and out points. Other times it just pulls up a small dialogue box and asks me to name the clip. Anyone know how to control this? Thank you.
