-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   What works for me - settings for A1 and Merlin (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/123451-what-works-me-settings-a1-merlin.html)
Ger Griffin June 10th, 2008 02:56 PM
I found it difficult to nail down the exact settings for the A1 and merlin.
Partly due to the fact that there are a few options on the cookbook.
After a lot of trial and error I've finally found what I believe to be the best settings for the A1 and merlin.
Locator pin in slot i
Weights- 1 mid and 1 finish on the middle of the spar.
The rest except for the start weight on the lower spar.
Set the arc out to widest.
Next the G-platz needs to be touching the bottom of the lens hood.
I wondered how this could be done and the answer is that you place the dovetail plate right at the back of the merlin (-3 or -4)
The vertical trimmer also needs to be almost at the very bottom.
After that its just tweaking.
I pulled the arc in a bit to make the drop time quite slow (2secs) and found this suited me a lot better. This resulted in very little pendulum effect.
This overall feels a lot more comfortable to hold as your arms dont have to be out as far therefor allowing for longer periods of use.
Hope this helps one or two of you.
I know I could have done with it!
Guy Shaddock June 10th, 2008 03:07 PM
Thanks Ger
I am going to try your settings. I did notice the extra weight of the Canon but the DVC was also a bit tiring if held for a period of time. I made a "poor man's" harness that works quite well at taking some of the weight. If there was a way of posting a picture I could post it so that others could make the harness.
Guy Shaddock June 10th, 2008 04:48 PM
Thanks, your settings work quite well. However I think my little Sony HDR HC1 is the best camera of the two for the Merlin. I may lose some quality and stuff but the HC1 "flys" beautifully on the Merlin with very little fatigue.
