-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Premiere CS3 fix for A1 24F/P in release 3.2 (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/120056-premiere-cs3-fix-a1-24f-p-release-3-2-a.html)
Steve Sobodos April 22nd, 2008 08:40 PM
A new release of Premiere CS3 (3.2) fixes several 24 FPS problems including thinking Canon 24F is 30F:
http://www.adobe.com/support/documen...3_2_ReadMe.pdf
Luke Ross April 22nd, 2008 11:17 PM
I was extremely happy when I heard this and updated my Premiere Pro to 3.2. I had always wondered why premiere required me to always render my 24f footage and wouldn't treat it the same as a 60i capture would.
Thanks adobe.
Taky Cheung April 22nd, 2008 11:25 PM
More than that! This release also detect drop out and insert RED frames into the footage to aware the user where drop out occurs. I already see that red frames on the timeline. I need to check also if the audio unsync is fixed after the drop out too.
Alex Chamberlain May 8th, 2008 01:31 AM
Boy, this messed the heck out of a few projects I'm on. I'd already been using the CS2 HDV 24F import template, which worked fine, but I'd had to compensate for a few dropouts by moving my audio back 01:06. Now, after updating, the audio is all offset forward by 01:06 in three projects. Oh, well. At least things should be cleaner from here forward.
Ryan Postel May 8th, 2008 07:48 AM
Does the update erase the temporary CS2 fix or is there anything you need to do first in order for it to work?
I had given up using the 24F on the canon because I was tired of the rendering.
