All Buttons close to the MIC not working
I took my Canon xh a1 to Florida Disneyland. I found out that the Zoom, Rec ON/OFF (all) buttons found near the microphone have seized to work. The main zoom, Rec ON/OFF work.
Is this some mechanical flaw that needs repair, or some setting I mistakenly set, causing it not to work. I am worried. Has anyone had the same issue? Thanks Sundar Ramamoorthy |
There's a button LOCK switch on the side. Try unlocking it.
Yep. Sounds like the 'Lock' switch on the right/front of the handle is engaged.
Thanks. That helped. I never knew that button existed till now :)
Its always nice when its just a lock switch doing its job. When you read a post like this, always like to see it end in a good way.
Glad you are back up and going. |
| All times are GMT -6. The time now is 04:18 PM. |
