-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Display Question (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/109776-display-question.html)
Denny Kyser December 8th, 2007 08:44 AM
Display Question
I just had this happen yesterday and again I am VERY new to this video work, I did a short video of the kids, and had left the display on, when I captured the video it captured the display also. Is this normal
Seems that before when using Vagas is did not do this, I am now using premier. Not sure if I had changed a setting on the camera making this happen, or its in the editing program, or I just need to make sure the display is off when recording.
Robert Phillips December 8th, 2007 11:56 AM
capture display
I am assuming that you used the video output to capture. This output does have the display information (what I assume you mean by "display") included if you select the appropriate variable in the presets (I have a custom key set to toggle it (see TV SCREEN on p71 of*the english manual)). The firewire output will never have this information embedded and I don't really know about the HDMI since I don't use it.
Denny Kyser December 8th, 2007 12:04 PM
I was using the firewire to capture from the camera.
Bill Busby December 8th, 2007 07:33 PM
You may have inadvertently had "character rec" ON in the custom function menu.
Bill
Denny Kyser December 8th, 2007 10:52 PM
Bill
I did do that, thought in the DVD I was watching it said to, thanks so much was driving me crazy, will turn it off tomorrow.
Denny
Bill Busby December 9th, 2007 12:38 AM
Glad you got it sorted out. Which DVD are you referring to? Maybe there's other "suggestions" people should be aware not to do :)
Bill
Denny Kyser December 9th, 2007 08:32 AM
Bill
Inside the Canon XH A1 by VASST.
Could have been my error, not sure.
