-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Record and Play button issues (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/109200-record-play-button-issues.html)
Nathan Quattrini November 30th, 2007 12:50 PM
My record button on the top handle gets stuck under the plastic to the right. Is it poor design or did something break?
Also, the Play button on the top handle doesn`t depress. All the other buttons push down and pop up. When I push play it works, but doesn`t depress at all...I`m not sure if its always been like that and i just noticed? Or is it broken as well? My camera hasn`t seen any hard times that would break the button especially since its covered %90 of the time, but I`m wondering if something got frail in the cold and broke? Is the button supposed to not move? Or is it like the other buttons that go down and up when pushed?
Bill Watson November 30th, 2007 01:43 PM
I think you've got a problem.
My record button operates smoothly. You might have a bit of grit in there.
Also, my play button moves the same as all the others.
Have you been to the beach with this thing? Sounds like you might have grit under the play button as well.
Nathan Quattrini November 30th, 2007 02:40 PM
no beach. The record button actually shifts, so when its pushed down it slides slightly to the right so it gets hooked and stuck under the plastic.
The Play button doesn`t seem like grit sense it doesn`t move at all but there is nothing visible to the eye around its edges. Feels more like it collapsed?
Nathan Quattrini December 3rd, 2007 09:40 AM
Whats the usual turn around time for sending the camera in for work? I haven`t contacted canon yet, was hoping others may know what the issue was, but if i were to send it in, how long would i be without it?
Paul Cronin December 3rd, 2007 09:59 AM
Nathan that does not sound right. My button just goes up and down.
Canon service is excellent I had a 4 day turnaround. I was able to talk to the tech when they had my camera on the bench.
Also they are in NJ so UPS for us in RI is one day each way paying for ground.
