-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Tape gets stuck when switching to SD (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/108731-tape-gets-stuck-when-switching-sd.html)
John L. Miller November 24th, 2007 03:38 PM
I have only had my A1 since the summer. So, this is the first time I ever switched from HD to 16x9 SD. I wanted to do some shooting in SD and as soon as I selected SD and clicked YES, I heard the tape mechanism make a noise then a red warning comes up that says "remove tape" . It flashed for a moment and then when I tried to eject the tape it wouldn't make a sound, I couldn't even open the outer cover. The tape was stuck some how. I kept switching the standby switch to lock and then back to standby while shaking the outer tape door and it finally opened and ejected the tape. I thought maybe just a freak thing so I loaded the tape again and had to go through it all again. Fortunately I was able to remove the tape. The tape is a Sony Premium and brand new. I have had no issues with it shooting in HDV, though I have only shot about 3 hours with the camera. So, in short, I threw the tape away. I installed another tape but left it on HDV instead of SD and it worked just fine. I am too paranoid about switching to SD and locking the tape mech. up again. Has anyone else experienced this, and if so, what is the problem? Thanks. J
Bill Pryor November 24th, 2007 04:25 PM
Was it a new tape or did it have some HDV footage already recorded? I don't think that would make a difference, but who knows. I've switched between the two formats before with no problem, usually with a tape in the camera, but always a new one.
John L. Miller November 24th, 2007 10:04 PM
It was a brand new tape straight from the package. It had not had one second recorded on it. J
Allan Black November 25th, 2007 04:06 AM
Try selecting SD before you load the tape.
John L. Miller November 26th, 2007 01:18 AM
Turns out it must have been the tape. I put another new one in and went ahead and shot in HDV since I wasn't having any problems there, but later tried switching and had no problem with the new tape. Thanks for your comments. J
