Pre-set and green square question
I usually shoot manual with the vividrgb pre-set. I have someone who ocassionally uses the camera who is not proficient with technical and really never will be. She does not use the camera that much and is not interested in devoting a lot of time. So be it.
She just turns the camera to the green square so if I have changed some setting it will not screw her up. The problem is the default settings are a bit flat. Is there a way to change the picture settings to something more like vividrgb when in green square mode? Thnaks Clay |
No. Just do it in post.
Don't green box it. It makes everything look like a morgue.
Show her how to set it to "Auto" and hit a preset of choice. 1 dial and 2 buttons. If she can't handle that, she probably shouldn't be using the camera. It's just going to make more work for you. |
I have a similar friend who can't comprehend camera controls and shoots on auto. It works about 95% of the time for him. The only thing I did was to crank down the auto iris about half a stop. Its default is too hot.
| All times are GMT -6. The time now is 01:05 PM. |
