-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   XH-A1 not on FCHD qualified device list (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/103065-xh-a1-not-fchd-qualified-device-list.html)
Philip Brubaker September 7th, 2007 11:22 AM
Has anyone else encountered this problem? Any way around it?
R.J. Esko September 10th, 2007 08:29 AM
I also use FC Express HD 3.5. The very first time I used the A1 with it I had a problem where it wouldn't see the camera. I had to play with the settings to match what I recored to the tape (HD, or SD). Then it was a matter of HDV Codec 1080i, or DV-NCTS, setting to capture. Other than that, my only problem right now is getting FCE HD to sync properly when capturing HD video. Hope this helps some.
Philip Brubaker September 14th, 2007 01:14 PM
this is somewhat helpful
Could this be a problem because of low memory?
Does Final Cut HD take up a significantly more amount of memory than Final Cut Express?.
Dom Stevenson September 17th, 2007 06:47 AM
Since the A1 didn't exist when FCPHD was around this is hardly surprising.
In fact as far as the 25/4 f setting goes it was only supported in the 5.14 version of FCP 5 if my memory serves me.
Phil Anderson September 17th, 2007 02:43 PM
So, other than FCP Suite 2, what are people using? (I'm not an editor).
Philip Brubaker September 19th, 2007 07:36 PM
Dom:
Yeah what are people using? If I have an XH-A1 do I have to get FC Suite 2 or Studio?
