-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   UV filter for protection (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/102727-uv-filter-protection.html)
Bill Pryor September 5th, 2007 03:08 PM
Nope. That's what it's for, to leave on all the time. The only time a UV makes any noticeable difference is if you're shooting a mountain in the distance or doing aerial photography, and it allegedly will help eliminate some of the haze look.
Peter Ralph September 5th, 2007 03:14 PM
you can leave the filter on all the time unless you are very particular about quality or there is a light source in the frame.
Stephen Sobel September 5th, 2007 06:56 PM
If I got the clear Hoya filter instead of the UV filter, would that take care of the light source in the frame issue?
Peter Ralph September 5th, 2007 07:09 PM
no - if there is a light source in the frame any filter can cause ghosting.
Stephen Sobel September 5th, 2007 07:15 PM
Sounds like if I want a filter on for full-time protection, a UV Haze filter is the best - covers outdoors and indoors situation.
From the comments, both the Hoya and B+W are excellent options. Thanks to all of you for the advice and comments.
Dirk Bouwen September 6th, 2007 11:25 AM
Whatever filter you take, there's one risk I experienced: the camera becomes much more sensitive to lens flare effects in clear sunlight. Problem is you don't notice it necessarily on the displays, but afterwards during editing.
Probably a bigger lenshood will help you, but it doesn't make your gear leaner in practical use.
Jack Walker September 6th, 2007 12:00 PM
I just shot 12 hours in a rehearsal hall shooting from all angles, often with lights in the shot (usually up high in the corner of the frame) I didn't see any problems from reflections or flares. As I said above I use the B+W multi-coated UV (10) filter. I think the multi-coating helps the reflections in my filter. Probably the same with the Hoya multi-coated.
Trent Humphrey September 6th, 2007 12:43 PM
look at my post....http://www.dvinfo.net/conf/showthread.php?t=102949
I use the www.cinetactics.com dv soft matte box they suggest for the xha1 and it works great for lens flares. I have a uv filter threaded on and then the adapter ring threaded on my filter that allows the matte box to be added. Its a great product and cheap compared to other matteboxes. Plus its soft!!
