Curse the noise
I've yet to manage to get a noise free image on my shoots and that's with mostly using a pair of 500w lights. My previous XL1 was great but as much as I like the picture quality overall I'm being driven nuts by this noise.
I'm shooting between 0db and +6db, nothing too mad? I could shoot with a wider f/stop but need to keep all in focus so therefore a tad of gain. Is there a way to reduce this noise? I have a de-noising plug-in for FC but it reckons to do an hour's footage on my C2D Mac - 3 days! Any help would be greatly appreciated :-) Mike |
What are you shooting, 1000 watts sounds like a lot of light, unless you are shooting a large stage lit from a distance.
What are you using for presets? That shutter speed? What aperture? |
I never shoot in anything over 0 gain. I usually am on -3. I make sure I expose the area in frame correctly that is the subject of the shot. Zoom right in as close as I can, set exposure, zoom out to the framing I want for the shot. I also have NR2 set on low.
I'm shooting at f/2.8 or wider so not extreme, only one stop down tops. Frame rate of 50. Most of the footage is shot wide and I use 25F as the main use is for web use so saves on de-interlacing. I'll try to find some still grabs to post but in many ways the noise is worse by the snow from frame to frame so I'd really need to post a few seconds of full size footage.
I have set up using several presets on here but will be spending the day experimenting. Maybe I need better diffusers on my lights. I am finding that if I set the lights so that hot areas don't burn means that I'm maybe running slightly under-exposed = more noise. While shooting video I also take stills with a Canon 5D etc so maybe I am just expecting more than the cam is able to give. |
> ...I also take stills... <
As you know, video is not the same as stills. In general, video lacks the latitude of still photography (and flash illumination), but makes up for it with motion and sound, which do have the effect of masking perception of other artifacts that would be glaring defects in stills. If the scene were lit to the same light level you need for a stills without a flash at the same shutter speed and aperture (say 1/60 at f/2.8) you should get a nice clean image. Try experiment a bit with the NR presets and the black levels. |
Thanks Don.
I never use flash, the stills are mostly taken at between f/1.2 (yes, f/1.2) and 2.8 using the same lighting. I was kind of comparing with f/2.8 and 60th to 125th ISO 200-400. I'll play with the NR and black levels :) Cheers Mike |
Mike, why not post a frame grab or short clip to show us the noise. Its hard to imagine the noise with 500 watt lights.
Here's a frame grab with similar (probably lower) amount of lighting http://www.jcdv.com/test/lowlightstill.jpg (Tweaked in post) http://www.jcdv.com/test/lowlightstill_raw.jpg (Straight out of camera) I was out of focus some on this shot and can't recall what preset I was using or exact settings, but 60i HD, I was zoomed in about half way I guess, full manual, and I'm going to guess I was on my low light preset I posted a while back. |
Hmm, thanks Jerome. I think that maybe I need to try fiddling with the noise reduction. I know that I tend to fractionally under expose as I have been caught out with blowing highlights before. I would expect to see a bit of extra noise but I have been getting a lot.
As much as I am grumbling, my main iMac 24" is currently rendering a 20 min interview with noise reduction (CVH) filters doing a great job of cleaning it up plus brightness tweaks, colour tweaks etc and to render down for web streaming at 720 x 405 will take about 10 hours - 2 pass H264. The picture quality after these tweaks is excellent, I'd just rather have that fixed in camera so I can be more productive, or maybe I should go get an 8 core 3GHz machine?! Oh, is there any way to view the presets in a not Excel Spreadsheet way? I don't do office apps! Cheers! :) Mike |
You can download the preset and put onto memory card and open in in your camera and you can go through all the settings and see what they are. Someone posted a program they made somewhere on here about viewing and editing presets.... Good luck. |
| All times are GMT -6. The time now is 01:20 AM. |
