XF-200 recording issue
Last night a theatre group that I am friends with allowed me to record a performance. I told them I had a new camera and wanted to check out some of the features and settings. This was NOT a paid job so, none of the problems are an issue for a paid job; however, I do have some paying ones coming up and I need to get this figured out.
I was recording in manual mode. MXF 50 Mbps 1920x1080 59.94i I was taping to a Transcend Compact Flash UDMA 7 1000x 64 GB Three times the camera stopped recording. I absolutely no warning the first two times. The third time I believe it said "buffer overload." I'm not certain because it came and went so fast. A week ago I recorded the same program with no issues. I used 35 Mbps 1920x10. Are these cards not capable of keeping up at the higher settings? Any idea what could have gone wrong? Thanks - |
Re: XF-200 recording issue
I use a 600x Transcend car and everything works out fine for me...Maybe it is a defective card...I have had cases like that before.
How old is the card? and where did you buy it? There are lots of fake cards on the market to that's why I ask.
It's about two to three weeks old, first time used, purchased from B&H.
I have the XF100 - for that camera Canon was very picky about what cards were recommended for it. Transcend was not on the list. Is there a similar list now for the XF200?
I've got the XF300. I've taken the Canon CF card list from the get-go and only use Sandisk. I'm using 60mbs ExtremePros. I'm needing to purchase some more tomorrow and they're going to be 90mbs - period. Canon had a firmware update to give me bigger recording rates, 90mbs are definitely going to be my minimum from now on - period!
Grazie |
Was the card formatted in that camera before use?
Scott. I started with a couple of Transend's a couple of years ago, both cards failed in what can only be called premature failures. I switched to Sandisk Extreme Pros and have used a variety of them over the last few years, none have ever failed, amazingly. I would venture a guess that the QC process for Transcend is not of the same rigor as Sandisk. But that's only a guess based on my limited experience.
By the way, why 59i? Why would you want to shoot interlaced with this camera for a freebie that could be shot progressive? Just curious, as I would never choose that setting normally. I've never shot interlaced in, oh the last 5 years? Not sure why I would. |
This particular show would not have made a difference, but I shot it in the format that I thought I would need in the dance recital environment. Last night I set the camera to the 35 Mbps using the same card, turned it on and let it run ... no problems. I'm going to do the same thing today at 50Mbps and see what happens. The only variable other than the setting is that I was using a L remote tripod control. I'm not sure why that would matter, though. |
Update:
I tried one more time just letting the camera run at 50 Mbps. It stopped recording after 15 minutes. So at this point I'm thinking its the card. It runs forever at 35 Mbps, but not 50. So ... I used my second card (new, 64gb Transcend) and ran it in the same slot at 50 Mbps. It made it 80+ minutes before it shut down. All of these have been in the "B" slot. I'm going to duplicate the tests in the "A" Slot to make sure the problem isn't there. I doubt that it is, but looking at everything I can. And I was asked earlier about a list of preferred cards. I don't believe that I've seen one. |
Here's the recommended list that came out with the XF100:
Canon U.S.A. : Professional Imaging Products : XF100 There is not a similar list on the XF200 page. I was mistaken, Transcend *is* on the list, but only for certain shooting modes. I just use SanDisk - they always work. I'm replacing my older ones with this now: http://www.bhphotovideo.com/c/product/1003355-REG/sandisk_sdcfxs_032g_a46_32gb_extreme_compact_flash.html I've never used anything larger than a 32GB card. Hope this helps. |
| All times are GMT -6. The time now is 03:27 AM. |
