-   Canon XF Series 4K and HD Camcorders (https://www.dvinfo.net/forum/canon-xf-series-4k-hd-camcorders/)
-   -   Viewing MXF video files on the PC (https://www.dvinfo.net/forum/canon-xf-series-4k-hd-camcorders/512793-viewing-mxf-video-files-pc.html)
Michael Gyori December 17th, 2012 04:26 PM
We own a Canon XF100 which outputs MXF video files. I can edit the MXF files in Sony Vegas, but have no way currently of just viewing the files (outside an editor).
WMP can't play them and VLC plays the video but the audio is sped up.
The Canon XF Utility Tool that comes with the camera is a nightmare of weird design that has only enabled me to accidentally delete card data rather than actually view it.
Surely there must be a free or inexpensive viewer for this file format on the PC. The only ones I've found cost over a $1000.
Any help in finding one would be greatly appreciated.
Al Bergstein December 18th, 2012 12:47 AM
Re: Viewing MXF video files on the PC
Michael, spend some timewith the Canon viewer, it's not that bad. I've never lost footage with it after dozens of sessions and thousands of clips. Caution is always the watchword, but i think you'll find it works pretty well.
Ann Bens December 18th, 2012 02:16 PM
I am trying to figure out how to use the Canon utility when clips have been copied to hdd.
Is it even possible.
Trevor Dennis December 18th, 2012 02:29 PM
I'm not sure this will help you as a Vegas user, but I just use Adobe Bridge. I tend to agree about XF Utility, and have bypassed it completely with my workflow.
Ann Bens December 18th, 2012 04:56 PM
When was the Bridge updated? Missed that one.
But one cannot use the Bridge if the clips are all in their seperate folder, to cumbersome.
During my last trip I had to empty the cards on a netbook so I basically copy/pasted the cards.
I would love to find a way to get all the clips in one folder.
Lee Mullen December 18th, 2012 05:46 PM
You can control audio speed in VLC. My mxf files play fine
Al Bergstein December 19th, 2012 01:02 AM
Folks, you can use "export to mxf" to strip the folder structure. This leaves you with the raw files that are easy to browse with abobe or vegas.
Roger Averdahl December 19th, 2012 02:41 AM
Yes it is possible if you don't rename folders and/or files. If you rename the folder CONTENTS to anything else it wont work. Use the Set Virtual Media in the File menu and "point" it to the CONTENTS folder.
If you have more than one card, place CONTENTS in subfolders:
D:\ProjectName\Media\Card_01\CONTENTS
D:\ProjectName\Media\Card_02\CONTENTS
D:\ProjectName\Media\Card_03\CONTENTS
D:\ProjectName\Media\Card_04\CONTENTS
I prefer to always put the CONTENTS folder in subfolders and then it should be enough to set the virtual media to Card_01 to see all clips on card 01.
Roy Feldman December 19th, 2012 05:43 AM
Windows 8 allows viewing thru the Media Player
Ann Bens December 19th, 2012 12:13 PM
Wow, got it finally working. Had all the cards the same way as you in subfolders.
But the utility would not let me set Virtual Media.
But then I realized I also had other video in a seperate folder in 'Media'.
Removed the folder and voila.
Al Bergstein December 19th, 2012 08:18 PM
Wow! That's significant!
Trevor Dennis December 20th, 2012 04:16 AM
I must admit I wondered about this when I wrote it, because Bridge would obviously have been updated when I installed Premiere Pro CS6. I have no way of telling if Bridge would have read the MXF files before that, because I had CS6 before I got the camera.
I have not been using XF Utility. Just downloading the clip folders to a named folder, and then searching that folder for .mxf files and moving them to another folder. Probably not the right way to go about it, but it works, and I still have the clip folders if I need them in the future. Shadow Protect backs this up every 15 minutes, and I do a manual back up to an external drive when I have either finished the project, or peridoically if it is an ongoing project. I just don't like XF Utility.
Roger Averdahl December 21st, 2012 03:03 AM
I cannot preview Canon MXF files in Win 8 using Media Player. Do you mean Windows Media Player or Windows Media Center?
Great that you got it working! :)
Charles W. Hull October 23rd, 2013 07:31 PM
I finally got around to loading Windows 8 on one of my computers (8.1, standard version, not Pro) and Media Player definitely won't play MXF files. Is there something I'm missing?
Roy Feldman October 24th, 2013 05:14 AM
Try the free Sony XD Cam Viewer: Sony | Micro Site XDCAM
