-   Canon XF Series 4K and HD Camcorders (https://www.dvinfo.net/forum/canon-xf-series-4k-hd-camcorders/)
-   -   XF100 Custom Picture Setting Menu=Not Available (https://www.dvinfo.net/forum/canon-xf-series-4k-hd-camcorders/512508-xf100-custom-picture-setting-menu-not-available.html)
Geoffrey Baker December 4th, 2012 09:33 AM
Trying to set up my new XF100 with custom picture settings. When I go into the menu [camera setup] and scroll down to [custom picture] the item is dim and not available to select and setup. I've tried with and without an SD card. Followed How to make Custom Picture Settings (XF105/XF100) and no dice. I can't select the custom picture camera setup. Any help appreciated.
Geoffrey S. Baker
Geoffrey Baker December 4th, 2012 10:05 AM
Re: XF100 Custom Picture Setting Menu=Not Available
For future reference for those searching for the answer...just got off the phone with tech support: A hard reset brought the function back. Now I just have to reset the entire camera to my liking.
Geoffrey S. Baker
Geoffrey Baker December 6th, 2012 12:21 PM
After a hard reset the issue came back when setting up the camera again. I sent my setup file to Canon and here is the bug: If you have [other functions]>[special record]>[pre rec] enabled.....the custom picture setting menu is NOT available. The workaround is to turn it off while you pick your camera picture setting, then turn it back on. Hope this helps somebody else in the same boat.
Rodolfo Pena January 8th, 2013 09:18 PM
Good to know that. Thanks for the advise.
Erick Perdomo February 14th, 2013 10:56 PM
just curious..how do you do a Hard Reset on the canon xf100? Is not the rest button...so exactly how?
thanks
Erick
