Which output to use for 1080 HD?
Hello ya'll, I recently upgraded to the XF 300. Wonderful camcorder. My question is, which output would give me the best results for viewing 1920 x 1080 HD on my flatscreen monitor, the HDMI connection or the HD/SD component connection? Thank you. Bob
Re: Which output to use for 1080 HD?
Remember, the component out is analog HD vs. HDMI is the digital out....so you will get a better/cleaner/sharper picture out the HDMI. If you hook both up to the HD TV and switch between them, you'll see the difference.
Jim Martin Filmtools.com |
Jim, thank you. That is exactly the information I needed. Bob
| All times are GMT -6. The time now is 09:29 AM. |
